How can I get the Color palette window in DMXControl 3 to use all available color channels in the selected fixture? eg. Amber and White not just R,G,B.
The Color window is currently showing HSV; is there perhaps a different scheme I can choose?
I'm only asking this because of the very exciting descriptions mentioned under Color It! on this page: https://www.dmxcontrol.de/en/dmxcontrol-3/features.html
Thank you!
Color Palette in GUI
benz -
December 10, 2024 at 4:38 AM -
benz
December 10, 2024 at 4:50 AM Changed the title of the thread from “Color Wheel in GUI” to “Color Palette in GUI”. -
Hello!
For setting up the additional color values for like amber or uv, individually, you have to use the device control. There you can expand the entry color, where you will find the further colors - as long as the selected device or at least one device in the selected device group has one of them.
From scratch, there at least for white and amber an automatic handling implemented, which can adjust for amber directly in the DDF.
Hi,
other than Stefan stated, there is a way, that Amber and White is mixed automatically. In the settings of RGB+ devices (the "+" stands for the non-RGB-colors), there are options for the automix mode. Those here are for amber and white, but it works for the others (except UV) as well:
whitechanneldefaultmodeThe mode, how white is mixed onlywhitenone,addwhiteoronlywhiteamberchanneldefaultmodeThe mode, how amber is mixed addnone,addoronlyYou can select them and the colors are mixed automatically to the selection of the color you choose in the color wheel (that is important, that you choose the color wheel for that).
Thanks guys. Do you mean I should edit my DDF? Here it is; comments welcome! All 5 color channels are working fine, but when I choose a color in the Color window it only uses the RGB channels not the others.
XML
Display More<?xml version="1.0" encoding="UTF-8"?> <device type="DMXDevice" dmxaddresscount="11" dmxcversion="3.1.0" ddfversion="1.0.1"> <information> <ddf-library-id>99996</ddf-library-id> <model>Event Lighting PAR12X12L</model> <vendor>Event Lighting</vendor> <author>Ben Zimmerman</author> <mode>11-Chan</mode> </information> <functions> <dimmer dmxchannel="0"/> <rgb> <red dmxchannel="1"/> <green dmxchannel="2"/> <blue dmxchannel="3"/> <white dmxchannel="4"/> <amber dmxchannel="5"/> </rgb> <strobe dmxchannel="7"> <step type="linear" mindmx="0" maxdmx="9" val="0"/> <range type="linear" mindmx="16" maxdmx="255" minval="0.1" maxval="20"/> </strobe> </functions> </device> -
Yes. In the color window, the HSV value you set in the color picker will be recalculated to a RGB value automatically, which automatically consists also values for white and amber according to the settings you set in the properties for that device as
JPK explained. All these calculations are part of and made in the hardware abstraction layer (HAL) inside DMXC3. So from that point of view you don’t need to worry about setting any values for amber or white.
Only if you would like to create a color completely by yourself, because you can’t find a good point inside the color picker, you can use the device control for controlling each color individually.
Regarding your current DDF will be used the default behaviour to add / include the color amber to the final given color of your device. But there is a possibility to shift the range, when and „where“ the amber should be added to the output in which intense. Here you can take also a look inside our documentation about the syntax of DDFs in / for DMXC3.
