Posts by benz
    Thanks guys. Do you mean I should edit my DDF? Here it is; comments welcome! All 5 color channels are working fine, but when I choose a color in the Color window it only uses the RGB channels not the others.
    So I'm resigned to changing colour only, but even that is not working. I've got my custom colour saved in a Preset against the device group--just the Colour property nothing else. I've then applied this colour preset to other 'scene' Presets where I've selected certain devices to have that colour at a certain intensity. No big deal right? A colour preset used in a bunch of other presets. But now when I go to adjust that colour, and save it back to the same Preset using Replace, I get a warning about references. If I accept that prompt, it updates my colour preset correctly but WIPES OUT all references to it in other Presets. Very sad. Thank you kindly for any tips or advice you can give...
    What am I doing wrong here? I want to tweak the intensity (for example) of all devices in a Preset. If I hit "Edit in Programmer" on the Preset, it does not select the devices for me in Stage View - so how can I quickly make my intensity change?! With Cues, on the other hand, "Edit in Programmer" does select the appropriate devices for me in Stage View, which is so nice.
    Thanks for responding. Seems like another possible solution to my query is to have Tracking off and insert a blank Cue with no fixtures in it. Then I can fade everything to black no matter what fixtures were previously lighted. I will need to use tracking for some scenes, but mostly I need it off. But that setting is "per cuelist" so I guess will need to divide my play up into multiple cuelists. Not a big problem. Looks like cuelists can even overlap (more than one running at same time). Thanks again for your help.
    Hi there. I'm new to DMXControl3. I want to assign a certain colour and a certain intensity to a selection of devices, saved as a Preset so that many Cues can reference it. And then later I need to be able to edit which devices are involved, and also be able to tweak the colour. I'm trying to do this with Device Groups and Presets but it's not working. Can someone please suggest how best to do this?
