Hi
I am trying to experiment with changes in intensity due to midi velocity.
I've tried everything but haven't found a solution, rules for midi devices, etc.
Any suggestions?
Hi
Any suggestions?
Hi,
such controls were not really considered, when the midi configuration was implemented in DMXControl 3. However, without having tested it, I would suggest adding a "Fader" control in the midi configuration and manually configure the velocity information to this fader control. I am pretty sure, that you have to do this manually because the learn function only reacts on the first midi message and this is typically the note change for such constellations. Maybe you can check the midi messages send to your computer with another tool (I unfortunately does not know a good one to use, but maybe you have one) to find the correct settings for the configuration in DMXControl 3. But if this fader control is set up correctly, then the rest is straightforward: In the input assignment, you will get this fader control as another input in the midi section. Add this to a new Connection Set and add a cuelist node with a cuelist of your choice. Then you can trigger this cuelist by the button press itself and set the intensity of this cuelist by the velocity "fader" control (you maybe need a rule of three to convert the value range of the midi input to the range of the cuelist intensity). Did this suggestion help you?
I recommend MIDI-OX: http://www.midiox.com/
Thanks for the reply. The control with the fader was one of the things I tried, but it was not what I had in mind.
I want to control the intensity and length of the light with midi note length and velocity is exactly what I want.
If I create it with a button, the intensity does not change because it is a 0 or 1 response. It is like I want to change the intensity of the light with velocity.
However, there was a workaround. It is a little tricky, but could be accomplished by combining buttons and faders.
As a request, I would like to see velocity sensing in button mode. thanks.
Hi
Ok, then maybe my post was a little bit unclear formulated because that combination of button and fader was my suggestion (at least I wanted to give this suggestion
). The reason that the button control currently has no velocity feature is because the current implementation was made with midi control boards in mind and they usually have no velocity sensing (unlike keyboards). However, we need to overhaul the midi implementation as a whole anyways because there are some other issues in the current midi implementation as well. So I will take the velocity sensing feature into the discussion about the new midi implementation (when we start to discuss about that) and maybe we find a good way to implement it during this overhoaul in a future version as well (not 3.3.0 because here we have already a feature freeze).
Is there a list of some sort of Daw's that are known to work with your software?
Hello!
There is no specific list. Almost each kind of source of a MIDI signal can be used in DMXControl 3, so far the sent signals are something like a simple button, a fader or an encoder. When you use MIDI from a DAW, maybe you can define the type of signal.
Best regards, Stefan.
