I see, it worked.
So it's flexible enough to accommodate changes in device assignments.
Thanks.
I see, it worked.
Thanks.
Thanks for the reply. The control with the fader was one of the things I tried, but it was not what I had in mind.
I want to control the intensity and length of the light with midi note length and velocity is exactly what I want.
If I create it with a button, the intensity does not change because it is a 0 or 1 response. It is like I want to change the intensity of the light with velocity.
However, there was a workaround. It is a little tricky, but could be accomplished by combining buttons and faders.
As a request, I would like to see velocity sensing in button mode. thanks.
Hi
I am trying to experiment with changes in intensity due to midi velocity.
I've tried everything but haven't found a solution, rules for midi devices, etc.
Any suggestions?
こんにちは!
ユニバース 4、アドレス 243、またはユニバース 2、アドレス 1 など、DMX アドレスが高いデバイスをいくつか追加しましたか?
「はい」の場合、DMXControl 3の通常の動作です。次のデバイスにパッチを適用する場合、常にDMXアドレスが最も高いデバイスの後にパッチが適用されます-が唯一のデバイスであり、下のユニバースには十分なスペースがあるかどうかは関係ありません。
Best regards, Stefan.
I am using artnet as shown in the image.
I have the following setup to increase the universes.
Is this normal behavior?
Hi and welcome in our forum,
did I understand it right, that you place 32 Sharpys with 16 channels each in a universe and only get 31, then a gap of 16 and then the last one is moved into the next universe? Is that correct? I do not know any issues with this device placement function in the DMX universes yet. And also, I could no test it yet. If my understanding of your issue is correct, then this is a bug.
Yes, there should be 32 16-channel devices in one universe, but the last one moves to 2 universes.
