Using DMX Control with a midi foot controller
  • I have just found DMX controller on the web and it seems a good piece of software. I can see from the manual that it is possible to control the software via midi. However, can anyone tell me if it is possible to control with a midi foot controller that only outputs program change messages. I have an ART midi foot controller that I have tested using Midi Ox and can see that it outputs only midi program change messages, as per the manual. I want to be able to control my DMX lighting rig with the foot controller.
    Any help appreciated.
    Will
  • Hi and welcome to this forum,
    well I'm not an expert in midi (cause I don't use it ;)) but as far as I know, should there be no problem to use your foot controller with DMXControl. So just try it :D. Or do you need help to connect the foot controller with DMXC?
    Regards
    I have played with the software now and have found out how to connect a midi foot controller and define what is being transmitted by it - the information was buried in a manual. I have my ART unit connected now (used Midi-Ox to verify as I've used this before).
    However now I have seen another problem - you can cannot create a device unless a definition of the device exists in a pre-defined list - and my lights are not in the list (I am using a few KAM Parbars along with some Showtec Par 56 LED cans - there Is a Showtec Par 64 device defintion and I have looked at the device XML file which seems to be the same as a Par56 would be so might be usable). I' wondering if I could create a device definition XML document for the Kam units by copying one of the existing ones and changing the channel values. I know that the Kam unit uses 15 channels and the first three are used for the whole unit with the next 12 being split into 3 channels per individual lamp in the unit. I think that I can see how to do this.
  • To create the device definition (called DDF) for a new device, it is the easyest way to use an existing DDF. You can change the DDF in two way:
    • changing the XML-file by hand with an text editor
    • change the DDF with the DDFCreator (download here under DDFCreator)
    With the DDFCreator, it is a little bit easyer to place all objects (dropdowns, buttons, etc.). With the text editor, it is easyer to create the entries in the dropdown-menues. So some people (like me) use both ways to be faster.
    regards
  • OK thanks JP. That looks interesting. I have downloaded this and had a quick look.
    I have been reading the manual and am still having problems understanding the principles of DMX Control. I have been using a Showtec 48 channel lighting desk and it's really easy to program for my lights (I cant use this anymore as I no longer have a lighting engineer to operate the desk for me - I'm in a band and now have to control the lights with my feet - hence the need to use my midi foot controller).'
    What I'm trying to do is create number of light scenes where lights will show different colours according to which button has been pressed on the midi foot controller (for example button 1 turns all lights to white, button 2 turns all lights to red etc). I have read in the manual that scenes can be created but I not sure if this is the same thing that I want to achieve. I also need to have "chase" sequencies where a number of "scenes" are played consecutively, one after the other, according to pre-set timing, and the chase keeps looping back to the beginning until another midi command causes a different chase / scene to be displayed.
    Do you think that this can be done with DMX Controller?
    Thats all what DMXControl is programmed for. ;)
    You should use the "Effectsequencer" for creating the chases. In the MIDI configuration, when you configer your controls, it is then called "chasers" in the dropdown for selecting the "Module".
    You can even assign a function "next"/"previous" (chaser) to step through them if needed.
  • Hi HOC,
    Thanks for the reply.
    I can see the "chasers" option in the module dropdown of the midi configurator and can understand how this would be associated with a particular midi command coming from my foot controller. I will read the manual again today and see if I can work out out how to set this up. Thanks for your advice so far. I hope you don't mind if I come back with further questions. It might take a while before I fully understand how to program DMX Control.
  • Hi HOC,
    OK I'm getting the idea of how this works. First I connected my midi foot controller and was then able to define the buttons on it and what signal was being transmitted by each. I could see the signal in the "midi remote window. "Next I added some devices, although I had to create a new device using the DDF creator mentioned by JP earlier in the thread. I think that I did that correctly. Then I created some "scenes / cues" in the Cue list. Then I created some "chasers" with the effects sequencer by adding in cues from the list. Then I configured the controls for the midi using
    module = chasers,
    device/function = the chase name from the list
    channel = start
    Now I have a question
    1. if the channel value = start turns the chase on does it turn off automatically when I select another chase with a different midi message (e.g. press button 1 - start chase 1 press button 2 - stop chase 1 and start chase 2 ? If not then how do you stop a chase - it would be impractical to have a button on the midi controller to start a chase and then another button to stop it.
    I hope that your supported interface page is up to date as I have just ordered the DMX4All Transmitter Mini-USB-DMX as this seems to be the most reasonably priced interface cable.
    Edited 3 times, last by Scyam (October 24, 2012 at 6:16 PM).
    Quote
    it's quiet easy if you know it. :D
    Just use:
    module = chasers,
    channel = start/stop
    flag = toggle (set T-Flag)
    instead of
    module = chasers,
    channel = start
    Now you can push your button once to start, and next time to stop.
    Greets Uwe
  • Hi Uwe,
    Thanks for your answer.
    OK I understand what you mean but that's not what I want to achieve. What I want is for one midi button to start a chase and then for that chase to stop when I press another button to start another chase. When you are running this in a live band situation it's impractical to have to press a button on the foot controller to start a chase and then press it again to stop the chase before you press another to start a different chase. What is needed is this:
    Press button # 1 = stop the current chase and start chase # 1
    Press button # 3 = stop the current chase and start chase # 3
    Press button # 5 = stop the current chase and start chase # 5
    Can this be done? If not then the midi control function has no practical use. When you use a lighting desk like my Showtec Showmaster if you put the desk in chase mode and select a chase it automatically ends the previous chase. I have used a few desks and they all operate this way.
    Will H
    Edited once, last by Scyam (October 29, 2012 at 6:16 PM).
  • Hi to All,
    I have another problem.
    I have bought the DMX 4 All mini USB to DMX cable. I plugged it in to my PC and it loaded a driver from the included CD. Now how do I get DMX Control to use it?
    I have been in to "settings / output plugins" and I can see the DMX 4 All usb listed so I've ticked the checkbox. When I take the option to configure it all the text is in German (understandable as it a German product I suppose) however I can't understand it. I have selected COM1 as the port as i can see the DMX 4 All cable in my device manager under COM1 and it says that it is enabled.
    By clicking on one of the on-screen buttons in the configurator I can see some text on the config window that seems to indicate that the cable has been seen. It says this:
    Mini-USB-DMX-Interface MKII V1.10
    (c) 2009 DMX4ALL GmbH
    >>> https://forum.dmxcontrol-projects.org/www.DMX4ALL.eu <<<
    USB connected
    However when I go to the Effectsequencer (Chaser tool) and select a chase to run nothing happens when I click on the button nor when I press a button on midi foot controller.
    I can see the midi msg arriving in the Midi Remote window so I know that DMX Control is receiving the midi msg.
    I really need some help to get this working. Thanks.
    Will H
  • Hello Will H,
    I just will try to translate you the text in the Config-Window.
    From top to bottom, left to right
    Kommunikationseinstellungen -> communication settings
    Anzahl zu überwachender Kanäle -> count of aktiv channels
    Abfrageintervall -> scanning time
    Verbindung -> connection
    Senden -> send
    Setupmenü anzeigen -> display setup menu
    Interfaceinfo anzeigen -> display interface info
    Verbindung zum DMX-Transmitter testen -> testing connection to DMX-Interface
    I hope this will help you, I have an Digtal Enlightment IF so I don't know anything
    about the dmx4all.
    But just talk about midi.
    If you had connect the midi controller to your computer, open DMXControl
    and go to the settings menu.
    First you have to assign a Bank push the Add Button and write "Light 1".
    Now just push there on the Midi remote control entry.
    Here you cam configure your midi-controller DMXControl -Commands.
    First you have search in the Midi-in Port dropdown your Midi-in Port.
    If you get your Port, you can push now on the Midi Learn button.
    If you now push a Midi button on your Midi-Controller, it will apear
    in the config window above.
    Just rename the control name with the name of the button of
    your Midi-Controller.
    In the window under the control window ist the the command assignment window.
    Here you have to make your command for your control.
    If you will start an effect, just choose from the dropdown Module the entry
    chaser. In the next dropdown you choose your effect by name and in the channel
    dropdown you have to choose Start.
    Close the config window and go to the menu Window, here you chose the entry
    Midi remote control. A little window opens, check the checkbox aktiv and select
    the bank "Light 1".
    The window has to be always open, if it's close there will be no communication
    between DMXControl and the Midi Controler.
    Now just push the button on your Midi Controller you have assign.
    The chaser will Start.
    I hope you can understand my very worth englisch.
    Greets Uwe
  • Hi Uwe,
    Thanks again for your response. I had already done the things that you specify in your reply except for the "midi learn", which I will now try. I have now managed to get a dmx signal to a showtec par 56 led light (I used a device description from the DMX Control list). This seems to work if you use the "play selected chaser" button on the Chaser tool window. The only problem is that it takes 4 seconds for the light to turn on after you have pressed the button. Unusable.
    I still haven't managed to get the software to turn on lights with my midi foot controller but I'll try to set up a new definition for my controller in the Midi remote control entry window and see what happens. I'll let you know.
    Never apologise about your English. It's not bad at all.
    Will
  • Hi Will,
    can you make a screenshot of your Chasers Tool window
    with the first step marked .
    Quote
    I think you have a too long fade-in time, could this be right?
    Normaly the chasers starts immediately, with no delay.
    Just one tip for midi just try first, one midi-button start,
    and another midi-button to stop.
    Next time I will show you how to start/stop a chase
    with one button, it's a little bit complicated with midi,
    at the first time.
    But just try and see what happened
    I just learned DMXControl by try and error. :D
    I can tell you there is no better freeware programm in the web.
    If you have a little bit spare time, you could help us by
    the englisch manual. I just work with JPK on the german
    manual, but our englisch is not good enough for an
    englisch Manual.
    Uwe
    Edited once, last by Uwe (October 29, 2012 at 9:33 PM).
  • Hi Uwe,
    OK now I've got the midi foot controller turning on the light. The fade time was set to "0 0 0". I've set it to "0 0 1" and the delay is down to 2 to 3 seconds. Still not usable unfortunately. I can see from the change of data in the midi remote window that the message from the foot controller is being seen immediately by the software without any delay. So the delay is coming in the software.
    Starting and stopping a chase with one button will not give me the solution that I need. I need the current active chase to stop when I press the button for the next chase. I can't see any way to do this in the software. When you are using the "chaser tool" window, as far as I can see, you have to stop one chase before you can start the next. This is crazy.
    I've also just noticed something odd about how DMX Control works. I've set 3 cues or a single light, red, green and blue. I want to have a chase that cycles between the colours, first red then green then blue. so I set up a chase and added the cues. when I run the chase red comes on (still after 2 or 3 seconds), next should be green but when green comes on red stays on and likewise when blue comes on. So now the light is white. Surely the purpose of having a scene chaser is that as you move from one scene to another the previous scenes turns off. If you have to turn it off by having a blackout scene then you will have no light for the time it takes to get to the next step in the chase. I just can't see how this could be used in a real world environment. Am I completely misunderstanding how DMX Control works or just doing something fundamentally wrong?
    Will H
  • Is the delay in the DMX output also observable in the "Channel overview" window? If it is not, there's probably something wrong with the interface or there is a compatibility issue between your LED PAR and the interface (which can sometimes happen and has nothing to do with the software).
    Stopping a chaser when another one starts is no problem for DMXC. Group all the chasers you want to be mutually exclusive by adding a group name in parenthesis (e.g. "Chaser 1 (LEDPAR)"). Then enable the option "Execute only one chaser per group" in the chaser tool.
    Cues in DMXC use a "tracking" approach, as found in many lighting consoles. Each cue only saves the channels which where selected by check marks and leaves the other channels alone. This gives a lot of flexibility necessary for many projects. For you it means you will have to select all channels you want to change, even when this change is "setting the channel to zero".
    Kind regards,
  • Hi Stefan / Uwe,
    Here's something really odd - I just pressed the blackout button on the main menu bar a few times and amazingly the chase now responds instantly to the midi foot controller message. I shut the app down and opened it up a few times and it continues to respond instantly - so no idea what happened there but good news.
    Excellent advice about selecting all the channels and setting the values to zero for the colours not being display. this works perfectly.
    I'll try the Grouping now and see if I can get this to work.
    I'm not using my Kam Parbar device definition at the moment so that will be my next challenge. It could be that there is something wrong that device definition.
    Thanks for your help and guidance guys.
    Will H
  • Then the delay problem is caused by a specialty of your interface: It is capable to output less than 512 channels to speed up the refresh rate of the DMX universe. This can lead to problems with certain DMX devices which are not completely DMX-512 standard compatible.
    The problem is "fixed" by the blackout because this forces the interface to send all 512 channels. When you power-cycle the interface, the problem would reoccur.
    If I remember correctly, the minimal number of channels to be sent can be configured with the configuration tool from DMX4all.
    Kind regards,
    Ok, just upload the DDF of your Kam Parbar along with the manual of this device in your next post (we need the DMX-addresstable of the Kam Parbar). Then we can have a look over the DDF and see if it is correct. Important: zip both files, because this forum only supports a fiew filetypes including .zip-files.
    Regards
