What is the status of the next version?
  • In a few months, I will be teaching a workshop on lighting for the Puppet Guild of Greater Philadelphia, in the U.S. Part of this workshop will be me showing how I can control lighting cues using a PowerPoint remote control. Puppeteers are interested in this, since typically it is only one or two people doing a performance.
    I was able to get the remote to work with DMX Control by using a keystroke macro program that would convert the characters that PowerPoint uses to advance slides, to also send the keystrokes that DMX Control needs. PowerPoint also receives its keystroke signals, and so a person can use its sound and video playback abilities.
    In past correspondence here I learned that the next version of DMX Control would have the ability to re-map its keyboard shortcuts, and thus avoid the need for the keyboard macro program. I am also curious about the state of DMX Control's ability to trigger sound cues. The current version requires that you use a 2nd computer to run any sound or video cues unless you use my approach.
    However, it would be nicer to avoid the multiple programs, and just use DMX Control. How soon might we expect the next version to be released?? Will it have the ability to play sound and video cues?
    Joe Dunfee
    audio/video:
    well, DMXC is able to play sound cuse, at least since version 2.9 (I started with this version ;)), and I use this feature in allmost every project I have. The "audio-cue" is listed in the dropdown-menu for new scenes under "audio cue". The only problem is, that you can't stop an audio-cue remotly (only manually with the Audio-Stop-Button in the main-window). If you need some "light cues" at exact positions in the audiotrack, you can use the "Audio Player". The video-function is not integrated.
    updates/new versions:
    I think an update for the 2.11 version (maybe 2.11.1 called) could be launched in the next few months but this could be not true. Ray of hope: In the review of the "Developer Meeting 2012" (here, german site), Stefan Krupop said, the version 2.12 should be released in this year.
    regards
  • In past correspondence here I learned that the next version of DMX Control would have the ability to re-map its keyboard shortcuts, and thus avoid the need for the keyboard macro program.
    Do you think of DMXControl 2.12 or DMXControl 3.0 as the next version? If 3.0 then don't wait for it as DMXControl 3.0 won't have the audio player feature, this will be added in DMXControl 3.1 which will clearly take some time to hit the ground.
    On the annual meeting the team decided to speed up the release of the 2.12, so the update will be included in there. Within the next aproximately 3-4 months the version should be released.
    But I can't tell you something special about the status of the keyboard-system. As far as I know there are no big changes in that module. Except the fact that it will be possible to use F1 now. ;)
    Video playback right out of DMXControl is still not possible without further programs. Sound-playback was always supported as JPK wrote.
    Sorry that I don't have better news for you,
  • The version I had used in the past was on a broken computer, so I don't know the version number. As I think about it, the biggest problem I had was that the English manual was not clear enough on a number of subjects. Everyone here was quite helpful, and part of the problem was that I was trying to make the program do things it wasn't really programmed to do.
    I probably didn't investigate the program's audio ability, since I was focused on a show that needed video. My current system uses PowerPoint as the media player, but I will check out DMX Control's ability to play sound cues, since video playback is not normally needed for puppeteers.
    Has the English version of the manual been worked on over the past year? Do you think it is safe to set a bunch of DMX novices loose on the program?
    Joe Dunfee
