hi, i am trying to use encoder with MIDI, when begin learn with midi input and assign it clock and anti close wise after that i go to (input assignment) and put that encoder there and rotate the encoder on physical MIDI it does not work infact it shows some kind of data in 0.01 or 0.02 but it does not work smooth however if i use it as a fader it works well from 0 to 1 level. need help on this thankyou
Encoder not working in DMXC3
Adil Amin -
August 28, 2025 at 12:19 AM -
Hi, can you check, if your midi controller sends two midi signals? Maybe this interferes in the learn process.
when i use encoder and begin learn in midi input it says move clock wise and anti clock wise, i follow the process and it learns successful but not working in input assignment and the midi is brand new i check the data output of midi with other software, it works but not with DMXC3
What kind of MIDI controller is that? Do you have some specs and maybe a picture or manual?
