Hi, I am facing issue, when ever I want to move beams at a specific position then I have to turn button ABS to REV on each beam PAN TILT and then save to cue,
Simple explain, if I have 10 moving heads. I position all beams at a single point and save it as a scene. However, when I trigger that scene and apply an effect, the fixtures move back to their original positions instead of using the saved position as the centre of the effect. Is there a way to make the effect start from the saved scene position?
I always have to press ABS to REV on each beam PAN TILT carefully
