Delete on Cue not working
  • It is possible to make and copy cue's. It is not possible to delete Cue's.
    Also when i want to alter a cue with programmer it is not possible.
    I installed in a Windows 10 computer, i tried several mode's Windows 7 , 8 and as administrator. But nothing helps.
  • nutzer99 June 28, 2018 at 12:14 AM
  • Hi and a warm welcome to this forum :),
    you have to select the specific cue by clicking on the area right in front of a cue row in the cuelist editor. Then, the whole row should be highlighted and then you can alter or delete the cue. In addition: Did you try to do a double click on a specific cue in the cuelist? If yes, just do a single click and afterwards do a right click on the cue entry. Now you should see a popup menu with different options like editing the cue in the programmer or delete the cue.
    best regards
