Is their away to get the source codes for Dmx control ?
Thanks
Steve
Thanks
Steve
Hi,
both DMXControl 2 and 3 are freeware, but not open source. Why do you need it? What du you want to do?
Regards
Jp
Mainly for Debug ,,, I reached its file size limit ,,, & The program is to slow & maybe some tweaks later
1) Hopefully I can open some working files to edit & delete over 1000 Cue or more,,, since the program takes me over 10 minutes to delete one cue & it would takes Months to delete over 1000 cues
2) Why - The Program after editing text in the cue name box the program locks up after editing text
I use Task Manager & End DMXControl & I will than reload the program than I will delete some Cue & than I can add more cue But this is not a solution but is the only thing I can do right now
Holefully I can delete some cue's & I can speed up the computer & this is the only solution I can do at this time ,,, Than maybe run two computer,, one for each universe's 1 & 2 & this would reduces the file size for both computers which will decrease the "Repository_Scenes" File" & shorten the load up time
I hope this makes sense?
Please read my other Thread
"Cue Program "Repository_Scenes" File, is their a way to Edit them"
Cue Program "Repository_Scenes" File, is their a way to Edit them?
Thanks Steve
I Changed to a desktop Computer last sumer & I based it on a Single Thread CPU chart & Cost
CPU - I3-4170
Hard drive- ssd-240g
