I cannot get this to work, please tell me what I am doing wrong. When removing the comment from the GoboShake area, the device will not appear in the Device Manger list.
Editing post screwed up the code, sorry - trying to fix it.
Code
<gobowheel dmxchannel="3" ><goborotation dmxchannel="4"><step type="stop" mindmx="0" maxdmx="0" /><range type="cc" minval="0.1" maxval="8" mindmx="8" maxdmx="127" /><step type="stop" mindmx="128" maxdmx="135" /><range type="ccw" minval="0.1" maxval="8" mindmx="136" maxdmx="255" /></goborotation><!--<goboshake dmxchannel="3" /><step type="open" caption="Open" mindmx="0" maxdmx="0" /> <step type="gobo" caption="Stars" mindmx="14" maxdmx="14" > <step handler="goboshake" mindmx="116" maxdmx="135" /> </step> <step type="gobo" caption="Cross" mindmx="28" maxdmx="28" > <step handler="goboshake" mindmx="136" maxdmx="155" /> </step> <step type="gobo" caption="Spiralgraph" mindmx="42" maxdmx="42" > <step handler="goboshake" mindmx="156" maxdmx="175" </step> <step type="gobo" caption="Meteor" mindmx="56" maxdmx="56" > <step handler="goboshake" mindmx="176" maxdmx="195" /> </step> <step type="gobo" caption="Blackhole" mindmx="70" maxdmx="70" > <step handler="goboshake" mindmx="196" maxdmx="215" /> </step> <step type="gobo" caption="Triangle" mindmx="84" maxdmx="84" > <step handler="goboshake" mindmx="216" maxdmx="235" /> </step> <step type="gobo" caption="Line of dots" mindmx="98" maxdmx="98" > <step handler="goboshake" mindmx="236" maxdmx="255" /> </step> </goboshake>--> <wheelrotation> <range type="cw" mindmx="220" maxdmx="255" minval="0,1" maxval="2" /> </wheelrotation> </gobowheel>
If I copy an existing DDF - Brightlight - Indigo 150, the device 'works', gobo buttons show up, how do I shake?
Code
<shake />
<step type="open" caption="Open" mindmx="0" maxdmx="9" />
<step type="gobo" caption="Stars" mindmx="14" maxdmx="27" >
<step handler="shake" mindmx="116" maxdmx="135" minval="0,1" maxval="3" />
</step> <step type="gobo" caption="Cross" mindmx="28" maxdmx="41" >
<step handler="shake" mindmx="136" maxdmx="155" minval="0,1" maxval="3" /
> </step>
<step type="gobo" caption="Sprialgraph" mindmx="42" maxdmx="55" >
<step handler="shake" mindmx="156" maxdmx="175" minval="0,1" maxval="3" />
</step>
<step type="gobo" caption="Meteor" mindmx="56" maxdmx="69" >
<step handler="shake" mindmx="175" maxdmx="195" minval="0,1" maxval="3" />
</step>
<step type="gobo" caption="Blackhole" mindmx="70" maxdmx="83" >
<step handler="shake" mindmx="196" maxdmx="215" minval="0,1" maxval="3" />
</step>
<step type="gobo" caption="Triangle" mindmx="84" maxdmx="97" >
<step handler="shake" mindmx="216" maxdmx="235" minval="0,1" maxval="3" />
</step>
<step type="gobo" caption="Line of Dots" mindmx="98" maxdmx="115" >
<step handler="shake" mindmx="236" maxdmx="255" minval="0,1" maxval="3" />
</step>
Display More
