Great Software - Now I have figured it out
  • A big thank you for this great software, I don't speak German so at first struggled a lot to work out what everything does but translating the user manual bit by bit in Google translate helped a lot.
    I found one bug in copying the composition cues. When you do this it makes a copy of the one you had highlighted but with the same name, not with 'Copy of' at the start like other parts of the software. Even if you then change the name of this copied cue anything you change will be changed in the original cue and the coped one.
    Other than that everything seems to work well with the functions I am using.
    Many thanks for this software :)
    Edited 2 times, last by djrocket (November 4, 2013 at 9:55 PM).
  • Hi and welcome in this forum,
    I don't speak German so at fist struggled a lot to work out what everything does but translating the user manual bit by bit in Google translate helped a lot.
    one of our current tasks in the documentation team is to translate our german manual of DMXC 2.12 into english. You can find an early version in the english part of our wiki (you can find it here). Uwe has translated the manual with an online-translator and look over it to find some faults. But we need some native speaker who can correct the manual and make some sentences more clearly.
    I think, DMXC works correct in this copy-case. When I have time to test it, I'll tell you, if it is a bug or not. But I don't know when I have time ;).
    Regards
    normally a copy in DMXControl 2.12 is not referenced by his name,
    the reference is referenced by the primary key of the internal database.
    I had tested it, just copied a composition cue in the cue libary.
    After copying, a new composition cue with "cue-name (unreferenced)"
    was shown.
    A change doesn't have an effect on the other cue.
    in which module did you copy the cue?
    Regards
    Uwe
  • Regarding the copy
    I go into Manage Scene Library
    Then expand to the Composition Cues
    Highlight one of the Composition Cues
    Click the Copy Button on the right hand side
    A duplicate of the highlighted cue will appear
    If I now click edit and change the name to something else it will take the name change
    However --- any changes to either the original cue or the new named one change both cues.
    I hope this makes more sense.
    Quote
    I can help with the English translation of the manual if you like?
    this is great, we need any help we can get. ;)
    Quote
    I'm wondering, this is the same way I do.
    I just have another look at the problem.
    With which version did you work, v2.12?
    Regards
    Uwe
  • Okay
    It the content of the composition cue is a COMMAND and like Chaser xxxx Start
    then you copy this and rename it also changing the COMMAND to Chaser xxxx Stop
    You will find the original Cue also has been set to Stop.
    It seems to work for Simple Cues okay however.
    jeah, this would be nice. The english wiki is unlocked (and Uwe or I can unlock all locked articles if necessary). With a wiki-user-account in the english wiki, you can edit all texts in all articles (please note that there are separate accounts for the forum, the english wiki, the german wiki and the Bugtracker, so you have to register in those areas you need, if you want to help us :)). If you want, you can send Uwe a PM (he translate the wiki-text) or a email at jens-peter@dmxcontrol.de (to me) or uwe@dmxcontrol.de (to Uwe) and he or I will give you a quick introduction in wiki-syntax and our special pages :).
    Regards
  • I have started editing the manual, I have just done the Foreword section so that you can review my writing style, if you are happy with it I will carry on.
    I might need some help along the way with some of the functions I have not worked out yet.
    Regards
    Ron
  • Hello Ron,
    Quote
    Great work, I like it. 8)
    Quote
    Okay I will send you the project what email address do I use?
    You can send also the "Pack and Go" as ZIP-Archive
    attachment with your next post here.
    Regards
    Uwe
    good work. You can carry on :)
    You will get the help, you need. With some parts of DMXC Uwe and I haven't worked either, but if there are major problems to understand in which way a DMXC module works, we can ask other guys in our association or even Stefan Krupop, the developer of DMXC 2.12.
    Regards
