DMX-510USB an Windows 7 64 bit
  • Hallo @ all,
    die oben genannte Kombination funktioniert nicht dmxcontrol hängt sich
    auf.
    Debuglog:
    03.10.2009 10:36:45: [ReplayManager] Class_Initialize: Subsystem ready
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Geräte (GUID={4F85EA29-0FD4-4CD6-A97D-58F9CCA3F9A2})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Audiotrack (GUID={95A17FBD-8D0F-4B4E-A3F4-3E5B950746F3})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: BeatTool (GUID={DC134A9D-2182-4672-9104-E245DAAC7EA6})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: KommandoBox (GUID={A80C922F-1B0A-43DD-93FE-9C9A9BF2A859})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Kommandozeile (GUID={BB49B6E0-4E50-4EBE-9E5E-F6224B4793EA})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Gruppenauswahl (GUID={C854B9DF-6E47-4A2A-9CDD-47A88EFB7E23})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: DMXIn-Remote (GUID={1CA4D3DB-D4C1-4FA2-822E-F7EDE85DD81A})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Effekte (GUID={DE5475E2-2F70-4646-AEF8-A0031A879709})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Master (GUID={C4F79916-27EA-46AD-B999-2009FD4DE2CB})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: MIDI-Remote (GUID={F33FFCE4-23F6-4937-BBBB-24B52F655207})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Szenenliste (GUID={5BD8CFBC-E989-4425-BAF2-38C801C305BB})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Submaster (GUID={EA7106C9-5E22-4394-AB33-BA90962852EF})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Textbuch (GUID={B26E7251-790E-4217-889C-D2E0F2165599})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Sound Analyzer (GUID={6C64921C-C601-4673-9F5E-F0FC71526F35})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: Szenenbibliothek (GUID={07E82F72-5DC1-478B-9829-A77458364CFC})
    03.10.2009 10:36:45: [CommandManager] GetAvailableCommandServers: Added new CommandServer: DMX-Ausgabe (GUID={EAAFBE89-4028-4AF6-A113-86DA48DA37CC})
    03.10.2009 10:36:45: [CommandManager] Subsystem ready
    03.10.2009 10:36:46: [CommandManager] CreateCommand: Created new command object (GUID=; FS=; SS=)
    03.10.2009 10:36:46: [CommandExecutor] ExecuteCommand: Value=100000
    03.10.2009 10:36:46: [CommandManager] DestroyCommand: Destroyed command object (GUID=; FS=; SS=)
    Driver Details:
    mchpusb64.sys
    Anbieter: Microchip Technology
    Datenverison: 1.0.0.6
    Die Software von Monacor sagt gleich 64 bit nein danke.
    Also hab ich den Shit mal auf nen Virtual PC geklatscht und da funzt alles aba nicht das jetzt einer denkt das sei ne Lösung.
    Edited 2 times, last by MC ASUS (October 3, 2009 at 9:34 PM).
  • ja was ist jetzt muss ich hier erst noch irgendwo Münzen einwerfen,
    ist meine Problembeschreibung mangelhaft
    oder fehlen noch Informationen
    Edited once, last by MC ASUS (October 3, 2009 at 9:37 PM).
  • Könnts vielleicht daran liegen, dass es sich dabei gar nicht um ein DMXC-Problem handelt sondern um eines, das sich auf Dein Interface beschränkt?
    In einem Parallel-Thread wird ja gerade von mehreren Seiten bestätigt, dass DMXC an sich unter Win7 in 32 und 64 bit läuft. Ich glaube, da wurde auch von funktionierenden DMX-Interfaces gesprochen. Gugst Du hier (da wurde auch ein erfolgreicher Test mit dem DE-Interface beschrieben)
    Ebenso scheibst Du, dass schon die mit dem Interface mitgelieferte Software ihren Dienst unter Win7 64 bit verweigert. Dann muss sich wohl der Hersteller um neue Treiber für das Interface für Win 7 64 bit kümmern - so vermute ich als Programmierlaie.
    Ob sich die DMXC-Spezialisten (also die, die diese phantastische Software entwickeln und kostenlos zur Verfügung stellen) sich durch deinen fordernden Ton auf die Zehen gelatscht fühlen, wird man Dir sicher noch kundtun.
    Original von Stagemanager75
    Also meinen Zehen geht es ganz gut :D
    Allerdings kann ich hier tatsächlich nicht helfen, da DMXC auch nur die Hersteller-DLL benutzt. Das Problem scheint ja noch etwas tiefer zu liegen, wenn der Absturz in der "mchpusb64.sys" auftritt. Diese ist ja scheinbar weder von DMXC (so viel ist sicher) noch vom Hersteller des Interfaces.
  • Wie ich oben schon geschrieben habe (aber das wurde ja wohl mal wieder überlesen) hab ich das auf einem Virtuellen PC mit XP Professional 32 Bit getestet und es hat funktioniert.
    Desweitern habe ich mal einen Notebook geholt mit XP Professional 32 Bit und da funktioniert, mal davon abgesehen das es für dieses Lichteffektgerät (CPL-3DMX) keine Geräte Files gibt und ich das selber noch basteln muss, auch alles eiwandfrei.
    Und das Thread was du da ansprichst hab ich natürlich mit der Board Suche schon gefunden und gelesen, bringt mich aber nicht weiter.
  • http://www.microchip.com/forums/tm.aspx?m=423310
    hmmm der Driver muss doch dann von Microchip entwickelt worden sein, und ich denke nicht das Monacor den grundlegend umgeschrieben hat.
    und dieses Problem was der da in dem Microchip Forum beschreibt
    ist ja wohl auch nicht gelöst.
    also ich hab die Kiste ja gleich wie ich sie ausgepackt hatte erst mal aufgeschraubt
    da mir das mit dem Driver schon komisch vorkamm ... also ich vermutete das da ein PIC drinn sein muss....
    ... mach das Teil auf und was glotzt mich da an ein PIC18
    Naja somit vermute ich mal wenn das mit deren Programm schon unter 64 bit nicht läuft ......
    aber welches IF sollte man den dann kaufen was unter 64 bit läuft
    Edited 10 times, last by MC ASUS (October 4, 2009 at 10:52 PM).
    Original von MC ASUS
    aber welches IF sollte man den dann kaufen was unter 64 bit leuft
    Jona$ hat in dem vielzitierten Thread geschrieben, dass er DMXC unter 64bit Win 7 am Laufen hat. Frag ihn doch mal direkt per PN, ob er schon ein Interface dran hatte, mit dem er erfolgreich DMX ausgegeben hat.
    Hier wird häufig mit dem Interface von DigitalEnlightenment gearbeitet und ich glaube, der Entwickler für dieses Teil liest hier auch mit.
    Bei "kommerziellen" Produkten würde ich eine Aussage vom Hersteller erbitten.
    Wie wäre es mit dem Umweg über Artnet? Dass die Treiber für das Netzwerk laufen, dürfte Microbensoft schon hingekriegt haben. Bei Soundlight hab ich ein Modul für Artnet nach DMX für ~300 EUR gesehen. Oder aber der "Artnet Node für 25 EUR", wie er auch hier im Forum kursiert.
  • Jo, das 25 Euro Teil ist ja irgendwie schon nice.
    Wenn ich mir hier so die Profi Teile so ansehe wo man unter 300 Euro nichts bekommt .
    Tjo die Qual der wahl ... ich weiß jetzt echt nicht was machen
    Aber so richtig will ich das noch nicht einsehen das mal wieder 144 Euro (DMX-510USB) für F & E drauf gehen.
    Ach ich ruf mal morgen da an (monacor) ...
    Für 25 EUR hast Du das Material. Dann kommt's noch drauf an wie fit du bist im "Basteln" und wie viel Dir Deine eigene Arbeitszeit wert ist.
    Quote
    Da kannste aber dann auch jemand an den E... packen, wenn's nicht tut - im Zweifelsfall gibt's die Kohle zurück. Und - Hand auf's Herz - irgendwie vertraue ich auf ein kommerzielles 300 EUR Gerät mehr als auf eine Selbstbaulösung, in der wohl noch meine eigene Unzulänglichkeit drin steckt :)
    Quote
    Naja, hat Monacor ne Aussage zur Kompatibilität gemacht? Wenn ja - Grund genug, alle Mittel des Gewährleistungsrechts auszunutzen bis hin zur Rückabwicklung.
    Wenn nein - dann dürften es wirklich F&E-Kosten (aka Lehrgeld) sein. Kannst ja auch mal in Redmond anfragen, ob die das als Migrationskosten auf Win 7 64 bit anerkennen und damit ihren eigenen F&E Etat belasten :)
    Im Zweifelsfall findet sich vielleicht jemand hier im Forum oder in der Bucht, der nicht mit WIN 7 64 bit arbeitet und ggf. mit Deinem Interface glänzend klar kommt.
  • :D find ich lustig ... das Ding bei den Säckeln absetzen :D...
    ... hab da heute morgen mal angerufen, wurde drei mal weiter vermittelt und der dritte man im Bunde hat mich nach einer E-Mail Adresse gefragt und mir folgendes geschickt:
    Sehr geehrter Herr Blaaaaaaa,
    im Anhang finden Sie die gepackten 64 Bit-Treiber für DMX-510USB. Die Datei bitte nach DMX-510_Treiber.ZIP umbenennen und entpacken.
    Mit freundlichen Grüßen
    MONACOR INTERNATIONAL GmbH & Co. KG
    i.V. Blaaa Blaaa
  • hahaha ich lach mit kaputt ... guter Witz ...
    alle Treiber Details gleich wie oben...
    und DMX-C killt sich immer noch
    hmmmmmm was können Amis eigentlich ...????
    Edited 3 times, last by MC ASUS (October 5, 2009 at 7:18 PM).
  • Tipp von mir... dein IF einmal zurück oder in die E-bucht und bau dir n DE-interface (oder lass dir eines bauen) das Interface hält von der Stabilität und Refreshrate, sowie der Performance mit der Grandma mit (ACHTUNG, ICH REDE HIER VON DEM TIMINGS UND DER BUSSTABILITÄT, NICHT VOM FUNKTIONSUMFANG) mit 100 Euro biste dabei.
    Grüße Souko
  • ach weißte 200 -300 Euro oder so ist mir fürn gutes IF auch nicht zu schade .... aber wer sagt den das jenes dann funktioniert ...
    ich hab jetzt mal freestyler ausgepackt und naja es tut ... so lala also ich mein ich kann es steuern ... aba das scheiß ding flackert wie sau wenn ich im Programm irgendwas rum mach ...
    Edited once, last by MC ASUS (October 5, 2009 at 9:19 PM).
  • Nicht die feine, sich selbst zu zitieren, aber trotzdem:
    Quote
    Jona$ hat in dem vielzitierten Thread geschrieben, dass er DMXControl unter 64bit Win 7 am Laufen hat. Frag ihn doch mal direkt per PN, ob er schon ein Interface dran hatte, mit dem er erfolgreich DMX ausgegeben hat.
    Das DE-Interface, auf das sich Souko und auch ich beziehe, ist nicht irgendeines. Es scheint hier in der DMXC-Gemeinde DAS Standardteil zu sein und wohl auch das mit der besten Unterstützung auf der Ebene der Entwickler.
    Hat sich JONA$ mal bei Dir gemeldet? Der wird doch nicht nur Bilder geguckt und dann "Hurra" gerufen haben?
    Selbst wenn Du es nicht zum laufen bekämst, wäre der Wiederverkaufswert hier ordentlich hoch.
    Oder es leiht Dir vielleicht jemand eins?
  • ... erklär mir erst mal einer warum das mit Freestyler jetzt funktioniert.
    Hab das jetzt auch noch mal auf einem Notebook mit Windows 7 x64 installiert geht einwandfrei.
    So und jetzt warum macht DMX-C überhaupt nichts .... über irgendwelche Hardwear ist immer schnell gemault ... mal davon abgesehen das DMX eigentlich totaler schwachfug ist ... aha DMX 512 ist also ein Standard ... jo und hier wird einem erklärt man muss sich ein wunder IF bauen das dann aufeinmal gehen soll.
    und dann nur 512 adressen, ein gerät brauch auch noch mehrere davon... und jetzt hier dieses da
    http://www.dmxcontrol.de/wiki/Art-Net-Node_f%C3%BCr_25_Euro
    oder vergleichbare IF's die es zu kaufen gibt.... lächerlich irgendwann ist der Zeitpunkt gekommen da ist ein System nicht mehr State of the Art.
    man kann sich mit IF's auch zu tode behelfen....
    ich versteh das einfach nicht warum man nicht einfach gleich die Geräte mit Ethernet baut....
    Edited 9 times, last by MC ASUS (October 6, 2009 at 7:41 PM).
    Zum eigentlichen Problem: Es kann nur sein, dass Freestyler die Hersteller DLL anders anspricht und sich damit irgendein Problem ergibt. Dazu kann aber leider nur Stefan eine Aussage machen.
    Zum "DMX-Wahnsinn":
    Ich verstehe deinen Frust durchaus. Aber frag Dich doch mal warum eigentlich alle Veranstaltungen DMX verwenden. Von DSDS im Fernsehen bis zur U2-Tour, die ganze Welt "spricht" DMX. Im Profibereich ist es robust, ausgereift und schnell genug. Einige Pulte geben zwar durchaus auch Netzwerksignale aus um dann ArtNodes anzusprechen (wie Du im Wiki ja schon eine billiglösung gefunden hast), aber die letzte Meile zum Gerät ist einfach DMX.
    Das Hauptproblem eines Systemwechsels ist einfach klar: Man müsste entweder eine halbe Ewigkeit zweigleisig fahren oder auf einen Schlag alles umrüsten. Da zweiteres unmöglich und ersteres zu komplex und fehleranfällig ist bleibt wohl noch erstmal alles beim alten.
    Außerdem stellt die von Dir vorgeschlagene Netzwerkstruktur ein größeres Problem dar. Jedes Gerät müsste entweder von einem Switch sternförmig versorgt werden oder aber einen Switch beinhalten. Problem beim erster Methode: Verkabelung ist gegenüber der momentanen Praxis erstmal unkonventionell und benötigt wahrscheinlich längere Kabel die dann im Truss nebeneinander liegen. Das ist eigentlich das was man mit dem Bussystem bei DMX verhindern wollte denn das ist fast so wie früher mit der analogen Steuerung. Um also das "alte" weiterstecken so wie bei DMX zu ermöglichen müsste jedes Gerät einen 3-fach-Switch beinhalten. Eingang, Abzweig zum Gerät und Ausgang. Interessant ist dabei, dass es dann total egal wäre wo was eingesteckt wird und in welche Abfolge. Kann dann aber auch zur Falle werden wenn keine feste Struktur mehr nötig ist und die Stagehands irgendwann 'ne Schulung zum verkabeln brauchen...
    Leider finde ich das Thema in einem anderen Forum nicht mehr wo genau darüber mal diskutiert wurde. Da waren Profis am Werk und die waren sich nahezu einig, DMX wird noch einige Zeit weiterleben.
    Im Party und Amateurbereich ist DMX überhaupt erst erschwinglich weil man eben "billigere" und damit (anfangs) auch zum Teil minderwertigere Interfaces und Geräte gebaut hat. Dabei ist der Standard dann allerdings den Bach runtergegangen...
    Ich verspreche Dir, wenn Du "amtliches" Material verwenden würdest, ist DMX absolut stabil und zuverlässig. Nimm einfach 'ne GrandMA, ordentliche DMX Kabel und >5000€-Geräte dann haste keine Sorgen.
    Willst Du was günstigeres, dann muss man eben suchen was dort das beste Preis/Leistungsverhältnis bietet.
    Warum gibts denn so viele verschiedene Telefone? Würde doch auch ein Modell reichen... Wählen, reinsprechen, hören, Kabel dran... ist doch auch alles Standard und genormt.
    Ich kann HOC nur beipflichten, erlaube mir aber diese Beobachtungen aus der Realität beizufügen.
    DMX ist als Schnittstelle einfach elend billig. Und bei Geräten, die ja eh nix mehr kosten dürfen kommt es in der Tat darauf an, ob der Controller und Schnittstellenbausteine 50 ct oder 1 EUR im Einkauf kosten. Und da sind die Begleitkosten durch höhren Codeaufwand und damit einhergehend mehr Fehlermöglichkeiten und mehr Debuggingauftwand noch gar nicht drin.
    Rechne für einen Hersteller für einen DMX-Knoten bis er läuft mal 3-4 EUR in Serie, für einen Ethernetknoten 14-20 EUR (zur Erinnerung, der 25 EUR Artnet Knoten ist nur die Hardware und augenscheinlich auch noch nicht perfekt)
    Die ganze Argumentation mit billigen Komponenten ist in der VTechnik auch wieder hinfällig. Diese Plastikwürfelzuckerstecker RJ 45 überleben wenn's hoch kommt 3 Einsätze, ein Office-Switch mit Steckernetzteil (brrrr) muss Dir genau 1 mal runterfallen und ist zerlegt.
    Ich beobachte das parallel in der Industrie. Da hieß es auch, dass ein Industrial Ethernet den ganzen Wildwuchs an Feldbussen (Profibus, Interbus, CANopen, DeviceNet, RIO...) niedermäht und die alleinseligmachende Lösung bis zum letzten Endschalter sein wird - so hab ich's vor 6 Jahren auf allen Messen gelesen.
    Die Realität belehrt mich täglich eines Besseren - zu jedem Feldbus gibt's jetzt ein Industrial Ethernet, die natürlich nicht kompatibel zueinander sind und sich auf einem physikalischen Netzwerk auch meist nicht friedlich koexistieren können.
    Die Beleuchtungstechnik kann glücklich sein, dass sie mit der einfachen Strippe, DMX und Artnet für jede Ebene der Übertragung nur EIN Standardprotokoll hat, das die meisten so leidlich sprechen (zugegeben, bei Artnet gibt's schon wieder Derivate - PFUI). Hin und wieder etwas MIDI und SMTP Timecode und gut ist. Und trotzdem kann das älteste Strand-DMX Pult grundsätzlich genau die gleichen fest installierten Dimmer ansprechen wie die neueste Hog, MA oder eben unser geschätztes DMXC.
    Also - Jubel und Tusch für die weitblickenden Kollegen aus den 1990ern, die sich darauf geeinigt haben DMX flächendeckend einzusetzen, obwohl schon damals technisch mehr drin war.
    Dein Problem, McAsus, haben Dir die Kollegen von Microsoft eingebrockt. DMXControl, verschiedene Interfaces und DMX haben sich in vielen Installationen bewährt - egal welche Version und wie alt und neu die Geräte sind, die zusammenarbeiten, ohne dass sie aus einer Firma mit gemeinsamer Entwicklungsabteilung entstanden sind. Das muss Microsoft erst mal vormachen.
  • naja für Linux gibts ja nicht grad viel DMX support oder nicht ?
    Und das der 64bit Treiber von monacor nicht stabil leuft ... naja was kann MS dafür ...
    Edited once, last by MC ASUS (October 17, 2009 at 11:34 PM).
  • Servus
    ich habe mir heute einen Laptop mit Windows 7 64bit zugelegt und habe auch das interface von Stageline USB510. Habe auch gerade eine Lösung zu dem Problem gefunden das sich DMXC immer aufhängt wenn man das interface als ausgabe auswählen will. Bevor man den haken setzt schon mal auf Config gehen und 510 auswählen sonst versucht er falsche treiber zu laden die es ja nicht gibt. Hoffe das hat ein wenig dazu beigetragen zur Lösung.
    Chris
