DMXC 3.3.2 RC2: is not responding with lights via Art-Net
    last night i installed DMX C 3.3.2 and patched my lights but its not giving any output from artnet and not working with 3d visualiser as well. I reinstalled 3.3.1 and check its was working perfectly. plase need solution.
  • Hello!
    So far you didn't change the selection during the installation, you were going to use the new version of the Art-Net output of DMXControl 3.3.2. Therefore you have to renew the configuration for the used Art-Net outputs, because the (old) settings for the Art-Net output in DMXControl 3.3.1 are not compatible to the new ones.
    If you want both version alternately, you have to separate the working and config folders by creating an environment variable. Otherwise you would lost the configuration for Art-Net in DMXControl 3.3.1. How to create this variable is described in our wiki - but in this case currently only in the German version: Systemkonfiguration
    Beside this: which Art-Net node(s) and which visualiser are you using?
  • LightningBrothers April 30, 2026 at 1:50 PM
    Changed the title of the thread from “DMX CONTROL 3.3.2 is not responding with lights” to “DMXControl 3.3.2 RC2: is not responding with lights via Art-Net”.
  • Can you please 3.3.2 with the new Plugin and Run Whireshark on the same Machine, then starting DMXC3.3.2
    After enabling Artnet for 2 min. please save the Whireshark-Capturing and attach it here
    Its mostly because the Art-Net nodes are to old or to cheap to heave a propper ArtNet implementation
    In that case the handshake of DMXC and the Nodes is not working and no Data whold be send.
    If you provide the Whireshark FIle i can take a look at it
    Github
  • LightningBrothers June 7, 2026 at 10:41 PM
    Changed the title of the thread from “DMXControl 3.3.2 RC2: is not responding with lights via Art-Net” to “DMXC 3.3.2 RC2: is not responding with lights via Art-Net”.
