Cuelist Release time not used when stopped from another cuelist
  • Hi guys,
    I have a cuelist with a single cue in it which contains a capacitor effect on the dimmer of a group of lights. The cuelist has a release time of 1s, and is set to "release at end: Manual Only". We'll call this cuelist B.
    Cuelist B is triggered from another cuelist - Cuelist A using the Special>CueList B:Go and then stopped using Special>CueList B:Stop and Release.
    However, when Cuelist B is stopped from Cuelist A it doesn't use the release time that I set - it just switches off instantly.
    If I stop Cuelist B manually it fades out over 1 second as expected.
    Can you think of any reasons why the release time wouldn't be respected when triggered from another cuelist?
  • Hello!
    When you create a special cue for cuelists, there should be also an entry called „Stop“. Did you also try this?
    Because usually, the entry „Stop and Relase“ provides the same behaviour, when you do a double click manually on the stop button in the cuelist editor window or double click on the button „Stop all cuelist“ in the left quick menu bar.
