I have been using DMXController 3 for stage shows at our school for several years. This year, I have a follow spot that I have programmed, and it is working nicely. But every once in a while I need to do fine adjustments on the fly. I saw that DMXController 2 had a joystick control feature, but I can't seem to find it in the current version. Is there a way to do this? I would LOVE to now have to use the mouse in the position window if possible.
Joystick control?
JosephOrlando -
February 22, 2025 at 4:58 AM -
JPK
February 22, 2025 at 7:52 AM Approved the thread. -
Hi and welcome in our forum,
currently we don't have a direct joystick control in DMXControl 3. However, we have a plugin for the 3DConnexion 3D mice (at least the basic ones). With them, you can control DMXControl 3 more or less like with a joystick.
Amazing! I will take a look. The other thing I was thinking was using GlovePIE to turn the joystick data into MIDI data. If I were to do that, is there a way to have a MIDI signal control RELATIVE position of the fixture. Or can it only control absolute position?
Yes... at the end, it's almost the same logic how you use the 3D mice, when you want to use a fader from a MIDI controller. But also a fader in a softdesk or just buttons are possible to use them for the relative control of the position and also some other functions.
