DDF Library Login Failure
  • Hello!
    I've encountered an issue while trying to login to the DDF Library using my forum credentials. I know the username and password are correct because I can login to the forum. But, when submitting my credentials on the DDF Library website, I keep seeing a "Login failed!" message. I've tried to reset my password. I also made sure that the "DMXControl Forum" option is selected.
    I did inspect the request data and captured the following error:
    JSON
      "error": {
        "code": 20,
        "message": "Bad User"
    Is there anyone that I can contact about this issue? I'd be happy to help troubleshoot.
  • Hmmmmm that*s interesting. I took a look into the forum backend to see, if you are listed as registered user. I can confirm, that this flag is set correctly. But I wrote to the DDFLib developer. Maybe, he has an idea, what the problem could be.
