I've created a few looping cuelists to fade between two colors. I have two follow cues each with a fade time of 5s. The light type is the default RGBW that DMXC3 has. I see an occasional fast flicker during when the cuelists run and I'm not sure if there is a setting that is causing this. My basic cuelist settings are attached. Any thoughts would be very much appreciated.
Cheers!
