DDF for Uking ZQ-B28
hi,
I want to use the Iking ZQ-B28.
I have try some DDF's but none will working.
I try to edit an DDF with DDFCreator 3n but no succes.
Can somebody help me with the DFF for the ZQ-B28?
Thanks an lot,
Dskaatje.
hi,
Thanks an lot,
Dskaatje.
The DDFCreator is based on an outdated Version of DMXControl. In the moment the usage is not recommendet.
The better choice is coding the DDF in an Editor like Notpad ++ or the Windows Editor with the help of the Wiki
Or you can post the manual of your device so someone else might code it for you
13 Channel Mode
1 0-255 Level
2 0-255 The level of fine-tuning
3 0-255 vertical
4 0-255 Vertical trimming
5 0-255 speed
6 0-255 Dimming
7 0-255 Strobe
8 0-255 Dimming red
9 0-255 Green dimming
10 0-255 Light blue tone
11 0-255 White Dimming
12 0-255 Self-propelled
13 150-200 Reset
11 Channel Mode
1 0-255 Level
3 0-255 vertical
5 0-255 speed
6 0-255 Dimming
7 0-255 Strobe
8 0-255 Dimming red
I'm trying to code a file for you, but i need more information
Behavior of the strobe channel (7 or 5)
How does the device react when the channel value is changed
e.g.
Behavior of channel 12 (13Channel Mode)
I assume that this is some kind of auto-Mode
But i also need value ranges
e.g.
The 13Channel Mode so far:
<?xml version="1.0" encoding="UTF-8"?>
<device image="ZQ-B28.png" type="DMXDevice" dmxadresscount="13" DefaultDisplayStyle="PREVIEW" dmxcversion="3.2.3" ddfversion="1.0.0">
<information>
<model>ZQ-B28</model>
<vendor>U'King</vendor>
<author>Soell</author>
<mode>13 Channels</mode>
</information>
<functions>
<position>
<pan dmxchannel="0" finedmxchannel="1">
<range range="540" mindmx="0" maxdmx="255"/>
</pan>
<tilt dmxchannel="2" finedmxchannel="3">
<range range="270" mindmx="0" maxdmx="255"/>
</tilt>
</position>
<ptspeed dmxchannel="4">
<range mindmx="255" maxdmx="0"/>
</ptspeed>
<dimmer dmxchannel="5">
<range type="linear" mindmx="0" maxdmx="255" minval="0" maxval="100"/>
</dimmer>
<strobe dmxchannel="6">
<step type="open" mindmx="0" maxdmx="0" />
<range type="linear" mindmx="1" maxdmx="255" minval="0.1" maxval="10"/>
</strobe>
<rgb>
<red dmxchannel="7" />
<green dmxchannel="8" />
<blue dmxchannel="9" />
<white dmxchannel="10" />
</rgb>
</functions>
<procedures>
<reset>
<set dmxchannel="12" value="150" />
<hold value="6000" />
<restore dmxchannel="12" />
</reset>
</procedures>
</device>
Display More
as i mentioned there may be problems concerning the strobe channel. And i left out Channel 12 as i don't know its behavior
Hi Fleckenzwerg84,
thanks a lot for the xlm file, I will give it an try.
about the strobe and auto-Mode channel I don't have manny.
Ukings is from China, so I don't have much.
Best regards,
Dskaatje.
Hey,
If there is no exact information about the assignment of certain channels, you can simply find out yourself. As I understand you, you have already fully connected your fixture to DMXC. Now you have to make sure that the fixture is set to the mode you want. So either the 9- or the 11-Ch mode. In DMXC, you can now open the channel overview via the menu bar at the top left. There you not only see the current value of each channel, you can also set values for the channels. I think you have to select the corresponding channel and then you can set the value via the fader on the left, but I'm not sure, I don't use the Channeloverview enough for that. Now you can simply pull up the channels that are unclear about the assignment and document what the device does with the corresponding values.
If there are still uncertainties, feel free to contact us again.
