Upgrade DDF2 to DDF3
  • Hello!
    Due to major changes between DMXControl 2 and DMXControl 3 related to the automatic handling of a lot of device functions it is not possible to simple upgrade a DDF made for DMXC2 to a DDF for DMXC3. So you need to create a complete new one, if you want to control that device now with DMXC3.
    But by the way: if you just want to control the brightness channel in the first step, you can just a generic DDF, the so called "Generic Dimmer" in 8-bit mode at the related DMX-channel.
    Best regards, Stefan.
  • That depends on the behaviour of the device. It could be enough for a first step to add a Generic dimmer to that DMX channel, where the DMX data need to sent out when you set your device to a specific DMX address - that means in your case the DMX channel 73.
    But according to the manual, will just control the auto show programs - in a not intuitive way. You always need to take the manual with you for look, which value need to be set for changing the program.
    But this is not necessary any more, when you build a "right" DDF for the device. Then, everything would be shown in a "clear text" in the device control or will be integrate into the other control panels (depends on the function generally). From that moment, you can let the manual at the bookshelf or you don't need to open the manual again at your phone etc. That's one of the main key features of DMXC3, that almost all devices can be controlled in the almost same way, because the needed "intelligence" is moved from yourself to the DDF and the software. ;)
  • Hi Stefan
    Can you please elaborate on this?
    Quote
