Posts by yancho
    Hi Stefan
    Thanks for your reply. I meant if in DMXControl 3 I set 'sound control' then I believe that they use their internal mics, even though they would still be controlled by the DMX.
    Quote
    So finally also your "switching effect" must be created in DMXControl 3 and send to the devices via DMX.
    Can you please elaborate on this?
    Thanks
    Hi,
    I would like to have an easy set-up. I would like to either control my 4 LED PARs 'normally' by changing colour and strobe or else put them on sound control. However, if I choose sound control then the LEDs would use their mic and the light would end up a cacophony.
    I would like to have 2 scenarios:
    Scenario 1: that the beats control only the strobe, and they use the colour that I set up in DMXControl3 - so basically they flash with the beats;
    Scenario 2: that the beat control the change in colour (as they are currently doing) but rather than switching on the internal mic, they use the plugin. I want that both groups (Internal and External) behave the same - so perhaps internal is red and external is green.
    I have set up the os2l+ plugin and also VirtualDJ 2021 is sending.
    This is where I am at, but I believe I have set it incorrectly:
    Any tips are extremely appreciated.
    Hi Stefan
    Quote
    But according to the manual, will just control the auto show programs - in a not intuitive way. You always need to take the manual with you for look, which value need to be set for changing the program.
