Translate
  • Thanks for the file.
    I have received 2 file
    xxxxxxxx.forms
    xxxxxxxx.variables
    but in the folder laguage the file is only one.
    ex. english.lng
    I have translate 3 or 4 rows and then I wanted to see if it worked.
    What i do?
    I have put the file in the folder language but dmxcontrol it does not see them.
    If i renane the file in italian.lng but dmxcontrol dont work and goes in error.
    What i must make ?
    xzero2
    ex. english.lng
    This is normal, as all the files for one language are compiled in the .lng file once the translation is done.
    Quote
    What i must make ?
    DMXControl needs a .lng file for the language to which it should be translated, because this file also includes the information about the translation. The data in the compiled version are overridden by the
    Italian.lng.variables and
    Italian.lng.forms
    files, so you can see your translations. I attached the Italian.lng which you will have to put in the "Languages"-folder.
    Regards,
  • Ok now i have understood ! ;D
    I must fully translate file.form and file.variables and then send you them.
    It will be along job :-[
    bye
    xzero2
  • No, as long as there is a Italian.lng DMXC will use your Italian.lng.variables/forms files. You only would send them to us when you have translated everything and want your work to be published.
    Try it: Put the Italian.lng in your Languages-Folder. Rename the files you got from Frank to
    Italian.lng.forms
    Change some obvious phrase, some menu title for example. Now start DMXC and select "Italiano" as the program language. When you restart DMXC your just translated caption should be shown.
  • Sorry but dont work.
    Now in laguage folder i have only:
    Italian.lng.forms
    Italian.lng
    I have translated some phrases in italian.lng.form.
    i have selected "Italian" ( there is only this one )
    But i don't see it when i start program.
    If i translate the same phrases in italian.lng with scintilla editor (http://www.scintilla.org), i see it
    Example
    [FrmAudioPlayer]
    cmdAddList=AAA
    I see it when i start dmxcontrol and open audioplayer
    If I change it in italian.lng.forms, i don't see it
    Xzero2
  • I would want translate dmx control, but it is impossible, many labels lack
    for example:
    in "file" "new project" --Buhnendefinition-- --Alle Dateien ---
    in "Graphical view" mouse right "Hintergrundibild andern" "gerat hinzufugen" ecc..
    other labels lack also
    these labels lack also in the English version
    xzero2
