Dear Sirsand Madams,
I have a problem with the DDF creator: every time I try to do the DDF file of Inno Beam Led from ADJ, it crash.
Can someone send me the DDF file or thell me where can i find it?
Thank you in advance!
Don't use the DDF-creator for creating your DDFs
It's completely outdated and doesn't work properly
Use an text-based Editor like Notepad++ and create them manually
An overview how to do this can be found in the Wiki
I guess you'll have to create several further DDFs in the future for your device, so i suggest you give it yourself a try.
When it absolutely doesn't work out for you there sure will be someone who can help with problems or even create the whole DDF for you
Display MoreDon't use the DDF-creator for creating your DDFs
Thank you for your answer!
I'll try!
Kind Regards
