We proudly present: The release of DMXControl 3.2.1!
JPK
July 15, 2020 at 10:00 AM -
3,775 Views -
0 Comments
Corona has caused delays in many places, so partly also with the release of DMXControl 3.2.1. However, also other things like partly quite late discovered, bigger problems have contributed to it. But now the time has come and we can present DMXControl 3.2.1! There are plenty of detail improvements and bugfixes: The developers have committed over 650 smaller and larger changes for DMXControl 3.2.1 alone! Thus, in the input assignment again many new nodes were added which make the use of the software even more flexible. In the Softdesk, many detail improvements were made. Here, the newly added controls, the now possible rotation of controls and much more have to be mentioned. In addition, some new effects have been added (Star, Star Polygons, Elipse, Static PWM) and a factor can now be defined while adding speed- / parameter masters to a property. With it, two effects, which shall be synchronized to the same Speedmaster can run with different speed (e.g. one with the doubled speed). Last but not least, the audioanalyzer is now available again. As always you can find a complete list of the changes in the release notes.
Download: https://dmxcontrol.de/downloads/cate…le-version.html
Release notes: https://dmxcontrol.de/en/dmxcontrol-3/releasenotes.html
Now we wish you a lot of fun with the new version,
Your
DMXControl Team ![]()
Comments
Newly created comments need to be manually approved before publication, other users cannot see this comment until it has been approved.
