1. Forum
    1. Unresolved Threads
    2. Threads of last 24 hours
  2. Dashboard
  3. News
  4. Members
    1. Recent Activities
    2. Users Online
    3. Team
    4. Search Members
  5. Discord
  6. Society
    1. History
  7. Shop
  8. DMXControl
    1. Übersetzung
    2. Bugtracker
  9. DDF Library
  10. Wiki
  • Login
  • Register
  • Search
Association
  • Everywhere
  • Association
  • News
  • Pages
  • Forum
  • More Options
  1. DMXControl Projects e.V.
  2. News
  3. Association
We proudly present: The Update for the Nodle U1
  • Logo DMXControl Projects e.V. JPK
  • January 19, 2022 at 10:00 AM
  • 2,518 Views
  • 0 Comments
After we released a small software update for DMXControl 3 at the end of the last year, we now present you a firmeware update for our Nodle interface.
Contents [hideshow]
  1. The new firmware features in detail
    1. Standalone function
    2. Heartbeat function
    3. Label
  2. News about the Nodle Config Tool
When we released the Nodle interface a few years ago, one of the reasons for this decision was that this is the only way we have access to the interface's source code and can thus also adapt or add new functions. With some interfaces from other manufacturers, we have only limited or no access. About four years ago we had already released an update for the Nodle interface, at that time with the repeater function (here again for reading: Vereinsnews - 18_KW09 - Pimp-my-Nodle / Nodle-Firmware 1.04). Now another update for the Nodle U1 follows. We are now upgrading a third standalone function: The "Static Scene Function". In addition, the interface now has a so-called Heartbeat function and you can provide your Nodle U1 with a digital label. To match this, we have now also updated the Nodle Config Tool.
Standalone function
There are now three standalone functions that the interface can perform when connected to a USB power supply. In the following the individual standalone functions and their effects are listed:
  1. Nothing: The interface starts into standby and does nothing.
  2. Repater: The interface will output all channel values it receives at the DMX-In. The DMX signal will be refreshed. The timings set in the interface are considered.
  3. Static from EEPROM: The interface will read a static setting / scene from the internal memory and output these channel values continuously.
Which of the three standalone functions will be executed is now set in the updated config tool. To do this, connect the interface with the current firmware to the PC, select it in the Config Tool and click on [Connect]. Now simply select the desired behavior in the Standalone dropdown and click on [Store]. If you select the option "Static from EEPROM", you can additionally select the corresponding channel values of the static scene. For this you simply select a mode with DMX-Out. Then you set the desired channel values with the sliders. Afterwards click on [Store]. The now appearing query is confirmed with "Yes". Afterwards the current DMX-Out values are stored in the internal memory of the interface. If you click on "No" instead, the DMX value transfer is skipped and only the timing parameters, the standalone mode and the device label are stored. If you leave the DeviceLabel field empty, this will not be overwritten/updated.
Heartbeat function
The Nodle interface now has a so called Heartbeat function. The interface sends now in regular intervals a short sign of life signal to DMXControl 3. Thus DMXControl 3 recognizes now whether the interface is still active or not and can warn you in the case of a loss of communication. Thus the use of the interface becomes now safer, because you can react faster, when problems occure.
Label
Finally the firmware offers, together with the help of the Nodle Config Tool, to store an individual short description on your Nodle U1. This label makes it easier to identify your Nodle U1, especially if you have several ones in use. You can use 32 characters for the label.
To flash the new firmware with the functions described above to the Nodle interface, you no longer need an external tool. The completely renewed Nodle-Config-Tool has received a corresponding function to update the firmware according to the Plug&Play principle. It also provides the current firmware directly, so you don't have to download another file. The same applies to interfaces that are not yet equipped with a Nodle firmware. In addition to the overhauled UI of the new Nodle Config Tool, there are serveral other new features. You can now for example execute a so-called loop-back test directly from the Nodle Config Tool - not only with your Nodle U1. You can also test your Nodle R4S with the loop-back test as shown in the screenshot.
We hope you like the new features of the interface and hope you have fun using it. All needed data you can find and download from the project site about the Nodle U1. But an important note at the end: The new firmware currently only works with the Nodle U1, i.e. the DIY version. For the Nodle R4S there will be an update for the firmware at a later date.
Your :dmxclogo DMXControl Team :dmxclogo
  • Developer News
  • DMXControl Projects e.V.
  • DMXControl 3
Comments
Newly created comments need to be manually approved before publication, other users cannot see this comment until it has been approved.
  • Smilies
  • Default Category
  • DMXControl
  • :argh:
  • :shit:
  • :P
  • :D
  • X(
  • 8o
  • =O
  • <X
  • :S
  • X/
  • 8)
  • :huh:
  • :rolleyes:
  • :love:
  • 8|
  • :cursing:
  • :thumbdown:
  • :thumbup:
  • :sleeping:
  • :whistling:
  • :evil:
  • :saint:
  • <3
  • :glaskugel:
  • Smilies
  • Default Category
  • DMXControl
  • :argh:
  • :shit:
  • :P
  • :D
  • X(
  • 8o
  • =O
  • <X
  • :S
  • X/
  • 8)
  • :huh:
  • :rolleyes:
  • :love:
  • 8|
  • :cursing:
  • :thumbdown:
  • :thumbup:
  • :sleeping:
  • :whistling:
  • :evil:
  • :saint:
  • <3
  • :glaskugel:
  • Previous News A happy new year 2022
  • Next News Save the Date: Live-Q&A about DMXControl 3.3
Related News
We proudly present: DMXControl 3.3.0 - the second release candidate!
It's time for a second release candidate for DMXControl 3.3.0.
March 6, 2024 at 6:00 PM
Like 5
0
We proudly present: The release of DMXControl 3.3.0!
It took a long time to develop. But it also contains an incredible amount: We are releasing DMXControl 3.3.0 today!
February 12, 2025 at 6:00 PM
Thanks 8
0
Developer News - 25_CW47 - Quick recap about the DevCon
From October 30 to November 2, our development team once again headed to DevCon. Unfortunately, the journey took only a few minutes.
Logo DMXControl Projects e.V. LightningBrothers
November 19, 2025 at 6:00 PM
Like 2
0
Categories
  1. Association 347
  2. Association News 206
  3. DMXControl Conventions 117
  4. DMXControl Convention 2021 3
  5. DMXControl 191
  6. Developer News 89
  7. Releases 13
  8. Did you know? 45
  9. Live@Work 40
  10. Current Maintenance Work 5
  11. Forum Guidelines and Informationen 5
  12. Reset Filter
Users Online
  • 8 Members (1 invisible) and 245 Guests
  • Record: 34 Users (November 24, 2019 at 7:46 PM)
  • ch700
  • Logo DMXControl Projects e.V. Frank Brueggemann
  • Logo DMXControl Projects e.V. Hoc
  • Logo DMXControl Projects e.V. nutzer99
  • Logo DMXControl Projects e.V. Homer-J-Simpson
  • Logo DMXControl Projects e.V. LightningBrothers
Legend
  • Logo DMXControl Projects e.V. Administrators
  • Logo DMXControl Projects e.V. DMXControl member
© DMXControl Projects e.V. 2018 - 2026
Gemeinnütziger Verein DMXControl Projects e.V.
Powered by WoltLab Suite™
  1. Terms of use
  2. Legal Notice
  3. Privacy
