1. Forum
    1. Unresolved Threads
    2. Threads of last 24 hours
  2. Dashboard
  3. News
  4. Members
    1. Recent Activities
    2. Users Online
    3. Team
    4. Search Members
  5. Discord
  6. Society
    1. History
  7. Shop
  8. DMXControl
    1. Übersetzung
    2. Bugtracker
  9. DDF Library
  10. Wiki
  • Login
  • Register
  • Search
Developer News
  • Everywhere
  • Developer News
  • News
  • Pages
  • Forum
  • More Options
  1. DMXControl Projects e.V.
  2. News
  3. DMXControl
  4. Developer News
We proudly present: DMXControl 3.3.0 - the fourth release candidate!
  • Logo DMXControl Projects e.V. LightningBrothers
  • November 22, 2024 at 6:00 PM
  • 2,742 Views
And here is the fourth release candidate for DMXControl 3.3.0!
Contents [hideshow]
  1. What else has happened in the meantime?
  2. What should you look out for?
  3. The download links
    1. DMXControl 3
  4. Final words
In this news we can start directly with good news: we were finally able to find and fix the problem that prevented those of you who work with an Enttec USB Pro DMX interface from properly testing DMXControl 3.3.0. With our fourth release candidate, DMXControl 3.3.0 will now be able to address these DMX interfaces again as usual and therefore be able to send DMX values.
Furthermore, in the third release candidate there was a problem with starting the kernel in certain constellations if several graphics cards were installed in your system. The workaround last described in the forum with the specific assignment of which graphics card should be responsible for the kernel should also no longer apply with this new version.
Addition from 26.11.2024 including an update at 15.12.2024: In the past few days it has become apparent that the output via Art-Net is defective and does not allow the kernel to work properly - to the point that it no longer starts. So if you are dependent on Art-Net for testing and working with DMXControl 3.3.0, please skip the RC4 and go directly to the RC5.
Apart from the issues with the interfaces, there was no other general focus that was “tweaked”. Rather, there were numerous small things that were corrected and improved both as a result of feedback from you and during internal tests. Our bug tracker contained the following tickets, which have now been worked on for the fourth candidate release:
  • FS#4432 : Parameter Master Node wird beim Start nicht aktualisiert.
  • FS#4674 : Ausgangswert eines Buttons wird bei Profillwechsel nicht zurückgesetzt
  • FS#4813 : Input Assignment / Softdesk: Cuelist Monitor leer bei Projekt laden
  • FS#5234 : fehlende Softdesk Cuelist Selector Aktualisierung
  • FS#5247 : TimecodePlayer - Unable to adjust cue start time for final cue in a cuelist
  • FS#5249 : Timecode Player UI - cue time adjustment is erratic / incorrect, and fade time is awkward to add
  • FS#5259 : Enttec USB Pro DMX Interface wird nicht erkannt
  • FS#5274 : Softdesk Slim Knob
  • FS#5286 : Bei Verwendung von Grandmaster Node Master bei Laden vom Projekt immer auf 0%
  • FS#5312 : Dirty Flag Timecode Player
  • FS#5323 : Color ITEM List Tabelle wird nicht aktualisiert
  • FS#5358 : Nodle U1 Heartbeat funktioniert nicht
  • FS#5363 : Projekt kann über Konsolenbefehl save nicht mehr gespeichert werden
  • FS#5364 : Timecodeplayer: Umbenennen von Tracks geht nicht
  • FS#5388 : GroupMaster beim Start auf 0% wenn diese Gerätegruppe im Input Assignment verknüpft wird.
  • FS#5389 : DMXC3.X.X Soundlight USBDMX-one funktioniert nicht
  • FS#5393 : Deadlock beim Bearbeiten von Cues
In our news about the release of DMXControl 3.3.0 RC1, we already gave you a few important tips along the way. These also apply with the release of this new version.
The download links
DMXControl 3
  • Release Candidate 4: https://dmxcontrol.de/en/downloads/2…-3-3-0-rc4.html
Final words
With the steady path towards the final version, the bug fixes and optimizations may not seem particularly extensive or even spectacular at first glance. However, they are another step towards the final release. We hope you continue to enjoy working with DMXControl 3.3.0. If you notice anything else, please ask or create a ticket in our bug tracker.
Yours :dmxclogo DMXControl team :dmxclogo
  • Developer News
  • DMXControl Projects e.V.
  • DMXControl 3
  • Previous News We proudly present: DMXControl 3.3.0 - the third release candidate!
  • Next News We proudly present: DMXControl 3.3.0 - the fith release candidate!
Related News
Developer News - 24_CW15 - Interface survey (again)
We want and need to start another survey - in the area of DMX interfaces. The reason has to do with the current development for the final version of DMXControl 3.3.0. But why?
April 12, 2024 at 10:00 AM
0
We have already published two release candidates for DMXControl 3.3.0. Today number 3 follows.
July 24, 2024 at 6:00 PM
Like 5
0
Developer News - 25_CW11 - Update for the Plugin template
It all started with an April Fool's joke. But it had a real ulterior motive: a template for plugins for DMXControl 3 was created. Now there's an update here.
March 12, 2025 at 6:00 PM
0
Categories
  1. Association 359
  2. Association News 214
  3. DMXControl Conventions 120
  4. DMXControl Convention 2026 4
  5. DMXControl 197
  6. Developer News 90
  7. Releases 18
  8. Did you know? 45
  9. Live@Work 40
  10. Current Maintenance Work 5
  11. Forum Guidelines and Informationen 5
  12. Reset Filter
Users Online
  • 11 Members (2 invisible) and 460 Guests
  • Record: 34 Users (November 24, 2019 at 7:46 PM)
  • Pyranha.T
  • Logo DMXControl Projects e.V. Mister X
  • Paul333
  • Logo DMXControl Projects e.V. Hoc
  • Logo DMXControl Projects e.V. Stefan Krupop
  • NSteam
  • Logo DMXControl Projects e.V. Frank Brueggemann
  • Helmut
  • Logo DMXControl Projects e.V. JPK
Legend
  • Logo DMXControl Projects e.V. Administrators
  • Logo DMXControl Projects e.V. DMXControl member
© DMXControl Projects e.V. 2018 - 2026
Gemeinnütziger Verein DMXControl Projects e.V.
Powered by WoltLab Suite™
  1. Terms of use
  2. Legal Notice
  3. Privacy
