DMXControl Kernel 3 as a Windows Service
  • Hello/Hallo,
    Example: Server backstage with uDMX and artnet-node / uDMX node software. DMXControl 3 Kernel as windows service.
    Any GUI client can connect, with the same configuration still running.
    Also, ability for the Kernel to load a file upon start would be nice. especially as a service. So keep a config file server side.
    This would work well for rtc timed environments. Windows service set to recover if crashed.
    Note: otherwise, the server will have to have an auto-login user with DMXkernel as startup item and maybe a security risk.
    Any followers on this one? Possibility of an embedded kernel device!
    Tony
  • Hallo TonyJr,
    you can manually install an application as service: http://support.microsoft.com/kb/137890/EN-US
    You just need the Resource Kit Tools for your distribution.
    For loading a project at startup just start Lumos.exe with the path to the project as parameter - it's as simple as that.
    PS: I filed two feature requests for this:
    http://www.dmxcontrol.de/flyspray/index…ls&task_id=1792
    http://www.dmxcontrol.de/flyspray/index…ls&task_id=1793
    Edited once, last by Stefan (September 14, 2013 at 1:02 PM).
