Chasers
  • I am using DMXControl to operate a simple system of dimmers and would like to create a chase cue. I have tried selecting "automatically created" and then "chaser". When I finish this process, DMXControl has generated a single cycle of individual dimmer cues by pattern number and steps. When I play this cue, the chase goes through the cycle once and stops. What I want is for the chase to continue cycling for a specified duration of time.
    The chase cue is now stored in my library, but when I try to add this cue from the library I can't seem to select the entire chase pattern, only one chase step at a time. So to create a chase sequence that repeats for a given length of time appears to be very arduous, and no easier than creating a thousand individual simple cues.
    I hope I am missing something obvious and someone can help me.
    I see also that "chasers" is listed as a command, but I can't figure out how to use it.
  • It sounds like you are using the "Cue list" tool, which is not the best selection for what you are trying to achieve (it is meant for a sequence of cues for e.g. theater use).
    Using the "Chasers tool" will give you much more options for chasers and is what the "Chasers" in the commands refer to.
    Kind regards,
