Posts by Mat
    I am using DMXControl to run a generic dimmer pack through the ENTTEC open USB interface. The program works fine except the lights flicker continuously at any level. The ENTTEC support center states this could happen because "some parameters (Break length, MaB length, inter-byte time) of the DMX signal can vary from frame to frame". They suggest adjusting the frame rate in the software, but I don't see how to do this. Has anyone else experienced this problem? I am not very technical and would appreciate any help or advice.
    Thank you!
    I am using DMXControl to operate a simple system of dimmers and would like to create a chase cue. I have tried selecting "automatically created" and then "chaser". When I finish this process, DMXControl has generated a single cycle of individual dimmer cues by pattern number and steps. When I play this cue, the chase goes through the cycle once and stops. What I want is for the chase to continue cycling for a specified duration of time.
    The chase cue is now stored in my library, but when I try to add this cue from the library I can't seem to select the entire chase pattern, only one chase step at a time. So to create a chase sequence that repeats for a given length of time appears to be very arduous, and no easier than creating a thousand individual simple cues.
    I hope I am missing something obvious and someone can help me.
    I see also that "chasers" is listed as a command, but I can't figure out how to use it.
