Enttec open source output plugin
  • Greetings,
    I have recently downloaded DMXControl, and am very excited about using it at Burning Man, the festival in the northern Nevada desert in two weeks. (burningman.com) I have 36 DMX addressable, dimmable, neon light ballasts with red, green, and blue neon lights attached (Digitran 50s?), and DMXControl looks so much better for my purposes than the limited Enttec software that came with the controller.
    I have searched and am struggling to find the Enttec output plugin. Could someone please direct me to it?
    Thanks very much!
    Dirk Schmidhofer
    Las Vegas, Nevada, USA
  • Hello Dirk!
    If everything works, please remember to make a video. When I went to the burningman-Homepage I remembered that I heard from it long time before.
    Sounds very interesting what you're going to do. =)
  • Thanks for all your positive response. Unfortunately, I am still challenged. When checking the box for "Next Generation Afterglow Slim", I get an error message:
    Error during activation of plugin "next Generatoin AfterGlow Slim": Error 429: ActiveX component can't create object
    Try again?
    I rebooted my machine, but still same error. Is there something else I need to try?
    Attached is a photo of the neons in one of six boxes. I tried to upload a cheap video from my phone, which Quicktime will play, but I think the forum software didn't like the extension (.3g2) :)
    Thanks again for all your help and possible suggestions.
    Dirk
  • My guess is, you are using Windows Vista and DMXControl runs not with administrative privileges?
    You should try this,
    got to \Program Files\DMXControl\
    and run PluginAdministrator.exe,
    confirm that it should run with administrative privileges,
    then check the checkbox next to Generation AfterGlow Slim plugin and close the window.
    Here is a wiki article which describes this problem, but its only in german.
    If you run the PluginAdministrator.exe, is it in german oder english?
  • Thanks fisl for your reply. I ran plugin administrator as you suggested from the command prompt, and set the checkbox for the Nextgeneration Afterglow Slim successfully. It does come up in German. However, unfortunately I don't know how to direct it's execution as administrator when DMXControl opens, and I still get the same error. I right-clicked on plugin administrator in Explorer, and under properties, Compatibility, Privilege level, there is a checkbox to "Run this program as an administrator" but it is greyed out and won't let me check it.
    :rolleyes:
    If you think of anything else, your replies are very much appreciated.
    Thanks all!
    Burner Dirk
    As far as I understand it, the "PluginAdministrator.exe" should ask if you allow it to run under administrator priviledges. So there is no need to do it via the rightclick-method.
    Did you try to run DMXControl.exe as administrator?
  • Hoc,
    Yes, I tried to run DMXControl logged in as administrator, but continued to get the same error message. No request from the PluginAdministrator.exe to run as administrator.
    I appreciate your effort.
    Thanks!
    Dirk
  • Hi Dirk!
    Okey, thats going to be more complicated than expected. Unfortunatly I don't own a Vista system or an Enttec interface. So I fear my help on this case is running out...
    Anyone else a further Idea??
    Edited once, last by Hoc (August 26, 2009 at 8:32 AM).
  • I'm having the same exact problem and I'm running windows XP sp3
    My device is fully working under MagicQ but not on DMX control.
    I get also a DirectX problem
    Also checked the admin rights
    Any other ideas?
  • I've had this same problem (not being able to start the Nextec Slim driver) and this is how I solved it. By the way, I'm running WinXP with service pack 3, and I'm always set as the administrator on everything.
    The PC isn't recognizing the dll's, that's the problem, so you have to manually register them. I'm not sure which ones did the job, I manually installed all the ones having to do with Afterglow. BTW, some of these drivers may have been installs I did of old Afterglow drivers. If you don't see all of them, register the ones you do see and that might do the trick. (if you need the old ones also, look around on these forums, they're available)
    The ones I manually installed were all in the DMXControl base folder (C:\Program Files\DMXControl\) and were:
    Afterglow.out.dll
    afterglow_Slim.out.dll
    AGlowdrv.dll
    AGlowthd.dll
    DllThreads_slim.dll
    All except AGlowthd.dll installed without a hitch, and AGlowthd.dll got started, so probably that's a good thing. As far as manually registering the dll's, Google "register a dll" and you'll find lots of instructions.
    Don't forget to acknowledge the plugin when it pops up the little box that says "NumDevices 1". Hit "OK" in that box... if you don't, you'll be dead in the water and wondering why the blasted thing won't work.
    Solved it for me.
    Chris
  • Pete C said "I'm using the Gus Electronics VL-344 (FTDI based interface)
    Had same issue with DMXControl + Afterglow slim driver with both WinXP SP2/SP3 and Win7 - eventually found a fix here:
    http://www.usb2dmx.com/index.php?option=…id=26&Itemid=32
    Note, page is in German (but it's really obvious where to download - or use your favorite translator).
    This alternative driver solved my problem immediately."
    I had same problem with same interface (Gus VL-344). Alternative driver worked for me also. I had some trouble replacing the existing .dll file so went and deleted it first and then ran the driver .exe file. THANKS FOR THE TIP!
