Effects - slow movement results in jitter / jumping backwards?
  • Hello again,
    I have a question about effects.
    If I apply a slow oval movement to moving heads (say 10* pan, 10* tilt, with a slow frequency of 0.05 or 0.03, the movement jitters. It either jitters forward, but quite repeatably also jumps back a bit and continues forward movement afterwards.
    "Fast" movements are ok (or fast enough to not notice problems - Frequencies above 0.1-0.15 are fine.)
    Overall it is terrible to watch and I would like to find a solution for this.
    The moving heads are Eurolite TMH-S180 controlled through a Eurolite FreeDMX Pro512 via Artnet. I have tried Pan/Tilt Speed adjustments, but it does not appear to make a difference.
    Here is a the pan/tilt section from the DDF:
    Code
        <position>
          <pan dmxchannel="0" finedmxchannel="13">
            <range range="540"/>
          </pan>
          <tilt dmxchannel="1" finedmxchannel="14">
            <range range="270"/>
          </tilt>
        </position>
    I suspect either
    a) DMX packages arrive out of order
    b) The head positions itself between receiving coarse pan/tilt and fine pan/tilt (hence jumping around)
    I am fairly new to DMX, so please forgive me if I miss some relevant information.
    Please give me any advice on how to fix this; I would really like to make some slowly but smoothly moving scenes.
  • namezero111111 March 15, 2026 at 8:04 PM
    Changed the title of the thread from “Effects - slow movement results in jitter?” to “Effects - slow movement results in jitter / jumping backwards?”.
  • Hello!
    I recognised, that sometimes the settings for pan and / or tilt invert could be the cause for that jittering when a slow movement is executed. For checking that in detail, you should check and change the settings for pan and / or tilt invert. After doing that, you control the channels for pan and pan fine respective tilt and tilt fine manually via the channel overview. When you are scrolling from 0 to 255 at the fine channel and increase afterwards the normal channel just by 1, the moving head should continue the movement into the same direction.
    If not, you change on the one hand the internal settings for pan and / or tilt invert and try again. On the other hand, you try to find out, if maybe you should not run through the whole fine channel. Maybe, the better range for the fine channel is only around 0 to 200 or something else. When you found out the highest possible value for the fine channel you can use, before the value for the normal channel is increased by 1 to continue the movement into the same direction, we can modify the DDF. With the modified DDF, you can try to run the movements again.
    I hope, you can follow "my test plan". If not, please let me / us know, where your understanding stops.
  • Thank you for your answer.
    Just to clarify:
    1. Inverting Pan and Tilt is "bad", it can mess with slow movements
    2. It has nothing to to with the interface or the way packets may be split up
    That said, I had tried already moving the channels manually; moving the fine channel slowly back & forth from 0-255 results in a good movement of the head.
    Moving the coarse channel also works ok but of course much more jerky due to the resolution.
    Your idea is interesting; I understand you are saying the fine channel "overshoots" the coarse channel; how can I change from 255 to 0 and the coarse at the same time from, say 0 to 1 at the same time to observe this? If I keep the fine at 255 and move the coarse to 1, it will move the 1,255, which is of course in the same direction, but we want to test 0,255 to 1,0.
    In either case, how can this be implemented in the DDF? Is there an undocumented parameter for the finedmxchannel that says range=224 or something? I suppose we should keep this a binary value?
    It is also worth noting that this isn't completely random; certain segments of an ellipse are predictably bad and others predictably smoother. I other words, I believe to have observed the jerkiness to be deterministic. This is why I am suspecting a programming issue.
    Fwiw I have also now purchased a USB to DMX to test another interface, and I have also tried Ethernet vs Wifi and wireless DMX vs cabled in all combinations, all with the same result.
  • Hello again,
    I have tried setting a fine value for 20-240 for example, but that just created awkward jumps (as expected).
    I did do another experiment though:
    - Made cuelist with two cues for different positions; P/T speed 100%
    - Fade time 20s on each cue and loop mode => Jerkiness is there
    - Fade time 0s; delay 20s; P/T Speed 1% => Heads move smoothly
    The issue is 100% related to the controller side (or DMX?); when the heads are in control they move smoothly.
    I have also disabled encoder feedback on the heads, but that made no difference.
    Also, using a different interface has made no difference.
