Hello,
I'm new to DMXControl 3. Therefore I'm not an expert and I might be doing something wrong.
I installed DMXControl 3.2.3 on my quite new windows 11 laptop. I tried playing around with the app using the online tutorial I just found that the "Input Assignment" panel doesn't show up. I started thinking that there was something wrong in the project, but I was not able to find anything. I tried also with a blank project but nothing changes.
So I thought that might be an problem of the 2.3.2 release and I tried the 3.3 RC3 but same results.
Then I installed the software on another windows machine with a fresh installation of windows 11 and the 2.3.2 release works as expected. The panel open right away.
Therefore I think it's not something related to the project, since I tried many different projects and demos, but nothing works.
It's not a common things because I was able to open the panel on another machine (so I think it's not me either
Maybe is somthing related to windows...
Or maybe is something in the application itself.
Probably not correlated to the kernel but only in the GUI, because if I start only the GUI the panel does not open anyway.
I attached the Logs.
Any ideas?
Thank you! Have a nice day!
Davide H
