automatic device selection in Stage View?
  • What am I doing wrong here? I want to tweak the intensity (for example) of all devices in a Preset. If I hit "Edit in Programmer" on the Preset, it does not select the devices for me in Stage View - so how can I quickly make my intensity change?! With Cues, on the other hand, "Edit in Programmer" does select the appropriate devices for me in Stage View, which is so nice.
  • Currently, there is indeed no automatic selection in the stage view if you edit a preset in the programmer. You need to select the included device group or the included devices “just” manually.
    When you take a look at the preset window, you can see, which devices or device group are included in the related preset. Or you open the programmer itself. Here you can see the values are set by the preset too.
