O.k. Not a total idiot here.
Just got a new pknight EasyNode ARS2048b artnet all commicating. Been more hardware than software. Telecomm admin here. I'm wondering to save some time. Like find a DDF that has the channels. Rename the fields and values and give it a new name.xml. Save it to be added into the list on my machine, so that I can use my fixtures. Scratching the back of my head here. I can see in the code to put the values between 0 and 255. Also see the fields to replace the name of the channel and such. One thing I'm wondering though. What about micro definitions? I can go with just the 0-255 easy. Any thoughts or tips? I do have the manuals for each fixture. Also as to import the file I make or edited into the list of fixtures to choose from. Also I would be more than happy to share the DDF once I confirm it works. I've got U'King, ADJ, and some Chauvet. I've already looked over some DDF's. Note: I'm an old DOS before Windows, and some Unix / linux person. Just really rusty on HTML.
No DDF's / creating / editing / impurting and a bit rusty on html. Thoughts
Jess_Tal -
February 4, 2024 at 6:48 AM -
JPK
February 4, 2024 at 7:36 AM Approved the thread. -
o.k. I found and got DDF Creator 3. Makes some since to me but, the on line help is in German. No disrespect here, but I do not speak or read German. Though I do have a translator. Is there some link directly that I can get so that my translator will work. Also still trying to figure out how to import the new DDF's I create so that I can test/use them.
Hi,
I would like to help you with your issues. But today, I have a lot of work to do so would it be ok, if I give you tomorrow evening (German Time
) a long explenation?JP
Hi,
now I had a little bit of time and started translating the wiki pages for DDFs (or at least throw them on a large language model and fixed the results so that they work in our wiki
). You can find the pages here: https://wiki-en.dmxcontrol-projects.org/index.php?title=DDF_DMXC3 They are not fully reviewed yet, but the current state should show you the syntax for the DDF XML and the important elements.The reason why I rather translated those pages than give you some infos about the DDFCreator is that the DDFCreator is very old and outdated. It represents the DDF syntax of an old DMXControl 3 version (I think it is 3.0.2 or 3.1.x). Since then there were some changes in the DDF syntax and thus the DDFCreator sometimes generate not working DDFs. We could not find a programmer yet, who will rewrite it (all of our developers are already working on different topics). So I highly recommend you to use a text editor of your choice to write the DDF by hand (I normally use Notepad++ with the XML extension enabled).
I hope, this will help you. If you have any questions regarding the syntax, then you can ask it here.
