Manual Crossfade
    I'm new to DMXC3, is there any ways to do (traditional) manual X-fade to proceed a cuelist instead of hitting Go button?
  • It is a function, that you have a fader or something semilar for doing the fade manually from cue A to cue B instead using the current available automatic trigger like "wait", "beat" or "timecode". When you do the fade manually, then you can pause at each position or can also go back to cue A.
    This is also a very old feature request in DMXControl 3 - see FS#280 : Manuelles Überfaden in Szenenliste
