Add device that isn't affected by blackout control
  • Hi all,
    I have a DMX switch pack which I am using to control a fan. I would like to be able to switch this on and off from DMXC3, but I don't want it to be affected by things like the blackout button or 'Clear all'.
    So I would like it to operate in a similar way to the fog control. In fact, a second fog control would also achieve what I need if that was possible.
    Is this possible, and if so, what is the best way to do it?
    Any help much appreciated!
    Phil
    the first part of your question is achievable by using a device with another property than the dimmer. DMXControl 3 even know the channel property "fan", so you can define it in the following way:
    XML
    <fan dmxchannel="0">
      <step val="false" mindmx="0" maxdmx="127" />
      <step val="true" mindmx="128" maxdmx="255" />
    </fan>
    Then you can switch it on and off like a normal switch, but it is not affected by the blackout-button.
    For the second part of your question just save the property values you want to be unaffected by "Clear all" with the value you prefer in a cuelist and run it. Then this value is active even if you hit the "Clear all" button. You can even assign a ParameterMaster on an intensity fan (not the switchable above!) by entering {ParameterMaster 1} in the Device Control. If you save this in the cuelist, then you can control the fan speed by this master, as long as the cuelist runs.
    I hope, this info helps.
