Audio Cues and Stopping Playback
  • Hi all, due to Covid we haven't run our usual school theatre production for a few years. Last time I used DMXControl and it worked fantastically. The one thing I was keen on was having audio in the cue list. It appears now that audio cues can be added to the list, and lighting can be adjusted to timecodes in the audio. I haven't quite gotten around to testing that yet. One thing I can't figure out is... once an audio cue is triggered, is it possible to stop the audio playing? At the moment, the audio cue starts, the song is played, but there is no way to stop the song and go back to the previous queue (something that will obviously come up in rehearsals). Am I missing something?
  • JPK June 29, 2022 at 9:18 AM
    yes and no :saint: There are special cues to start, pause and stop the audio file. As you already managed to start the audio, you can find the pause and stop command in the audio cue window as well. There is a small dropdown at the bottom of this window and there you can select the command you want to trigger. However, there is currently no way to fast-forward ore rewind in an audio track. This is due to the fact that the audio management is centralized and separate from a cuelist. The limitation of this structure is that the audio track does not stop, if you stop the cuelist and the generated timecode while playing the track is global. However, the advantage is that you can start an audio track in one cuelist and stop it in another one and you can sync multiple cuelists via the generated timecode.
    I hope, this answers your question. If not, keep asking :)
