Controlling DMX water pumps
  • Hi. I am exploring whether anyone has used DMX software to control (variable speed) water pumps (which follow DMX principals) and lights as part of fountain type system; pre-set sequences or following some audio files.
    I see the software and support tools (DDFCreator) are really focused on stage lighting and effects, but thought it work asking.
    I have found one company (Oase) which makes a plug-and-play system and supplies pumps and lights but it is exceedingly costly (!) and I presume is therefore mainly aimed at the larger-scale environment such as hotels etc.
    I am exploring how to achieve a similar result but using components at a more reasonable cost level.
    Any thoughts or experiences? Am I barking up the wrong tree with this
    Many thanks,
    Clive
    in our German forum area, there was a user who actually did a fountain controlled with DMXControl. Maybe you can read this thread: DMX-Steuerung für Musikbrunnen, Springbrunnen musiksynchron Unfortunately it is only in German, but maybe you get the Idea of it, if you try to translate it with DeepL (https://www.deepl.com/translator) or another translator. Especially on the second and third page there are some interesting facts.
    Regards
  • Hi CliveC
    a tip on the settings part:
    Don't use the actual DDFcreator. Its output files were made for the 3.0 & 3.1 version, while the actual 3.2 expects a little different syntax and some additional XML.
    Instead take the "notepad++" with the xml-addon getting your own DDF files ehich are descripted in the WIKI (sorry, it's german...) https://wiki-de.dmxcontrol-projects.org/index.php?title=DDF_DMXC3
    Oliver
