Issues with DMXControl 2 and velleman k8062
  • i'm using DMXControl 2 software with the k8062 velleman interface. I'm testing the setup with some led pars. The issue is that when i try to gradually increase/decrease the brightness of the fixtures it doesn't work linearly. It seems like the brightness increases in steps and it's easiy noticeable that is not a smooth transition. I've also tried the channel view to increase manually the dimmer channel.
    Can it be fixed or at least improved by software? I know that unfortunatelly the velleman interfece is kinda slow.
    DMXControl 3 may improve the situation?
    Thanks.
  • JPK May 14, 2020 at 6:11 AM
  • Try to patch the DMX Devices to one of the upper DMX Channels (e.g. 400+), and let me know whether that works.
    Reason: Some DMX Interfaces send small Universe Packets to frequent if the Universe is only partially used.
  • Do you have access to another DMX Interface that you could try out? Did you try on a different computer? Differential exchaning components is the only way to trace down the root cause of this issue.
