submaster @100% after update to windows 10
  • Hello
    I have recently updated my laptop to windows 10.
    I use it only for running DmxControl coupled with a Behringer LC2412 through a FX5 interface.
    After the update I am experiencing this strange behaviour:
    I start dmxcontrol (with or without the interface connected) everything works fine but, when
    the submaster window appears it has all the sliders with:
    - knobs at zero;
    - blu bar close to slider at 100%;
    I have tried everything to sot this out with no success...
    The only 'solution' is to click on the flash button for each channel and this is resetting the bar.
    To be honest before writing this I have tried to search the forum...
    unfortunately I was not able to find anything
    Can you help?
    Many thanks in advance
    regards
    Luca
    OS: Windows 10 Pro 32 bit
    PC: HP Elitebook 2560p
    Mem: 4GB
    Proc: Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz
    DMxcontrol v 2.12 Build 2
  • I think you want to write a cue program that you put all zero into the submaster
    you will have to do it for every submaster bar so the cue could have 1 to 12 steps or as many as you need
    Note-submaster will act up sometimes when you open/close them so you need to write clue w different Value & put them into the submaster & this will solve this problem 0 to 100%
