enttec OpenUSB
  • I just purchased an Enttec OpenUSB Widget.
    http://www.enttec.com/dmxusb.php
    and Im trying to get it going with DMXControl.
    however it dosnt seem to have the output plugin there to configure.
    please tell me how to do this, and or provide a current link to the download I need
    thanks
    Jay Binks
  • I now have this plugin installed and I can select the output plugin..
    however it dosnt seem to "Connect" to the device (like other software does..)
    with other software I ahve played with, I have the option to connect to my DMX Moving lights (which is what Im playing with)... when I connect to the lights they return to the "Home" position and stop their automatic, sound activated mode and they enter DMX Mode... this happens when I connect to the OpenDMX controller (With other software)
    but I cant make this happen with DMXControll (Yet)
    I have got the output plugin in the correct directory, I can see it in the output plugin list.
    I have a check mark beside it, and I have got the Frames per Sec set to 25 (which works in the other apps)
    please how do I tell it to Connect or Go Online or something...
    Thanks
    Jay..
    PS.. I have tried setting up devices in DMXControll that are set to the same chanels as my lights.. but again it dosnt seem to do anything :(
    little help please :P
  • It seems to have problems with DMXControl. It works fine with Freestyler and works on my main PC fine, but a new laptop has delayed output, and if I select a fader from the submaster it may or nor register the output.
    Hippy (the author) is doing a rewrite of the plugin to try to overcome the incompatability
