Artnet Interface setting 3.3RC
- eoiroroi
- Thread is marked as Resolved.
Hello!
If you need two or more DMX universes, you just add the Art-Net-Interface also twice or more. In each device, you define the settings, they are need to send the data right to your Art-Net node. In the column “DMX-Out address”, you set, which universe in DMXC should be send to the related Art-Net universe.
Stefan
I see, it worked.
So it's flexible enough to accommodate changes in device assignments.
Thanks.
