After a longer break now again something from the category "Did you known?". Due to current events, today's "Did you known?" revolves around the topic of device modes. Did you know that DMXControl 3 can now assign several device modes to one device compared to DMXControl 2? In DMXControl 2 you had to write the mode of the device in the comment field and select the device name accordingly. In DDFs for DMXControl 3 there is now also the "mode" parameter. Here you can specify the mode of the device for which this DDF was created. Since version 3.1 DMXControl shows in the "Add Devices"; dialog all DDFs for the different modes collected under the respective device. Also our new DDF library (see https://dmxc.org/ddf) uses this parameter for DMXControl 3 DDFs to assign all mode DDFs to a device. This should increase the clarity for you.
Your
DMXControl Team ![]()
Comments
Newly created comments need to be manually approved before publication, other users cannot see this comment until it has been approved.
