1. Forum
    1. Unresolved Threads
    2. Threads of last 24 hours
  2. Dashboard
  3. News
  4. Members
    1. Recent Activities
    2. Users Online
    3. Team
    4. Search Members
  5. Discord
  6. Society
    1. History
  7. Shop
  8. DMXControl
    1. Übersetzung
    2. Bugtracker
  9. DDF Library
  10. Wiki
  • Login
  • Register
  • Search
Did you know?
  • Everywhere
  • Did you know?
  • News
  • Pages
  • Forum
  • More Options
  1. DMXControl Projects e.V.
  2. News
  3. DMXControl
  4. Did you know?
Did you know? #22 - Version numbers for DDFs
  • Logo DMXControl Projects e.V. LightningBrothers
  • March 12, 2019 at 10:00 AM
  • 2,338 Views
  • 0 Comments
Why it is a good idea to note the exact version number inside the DDF file? You can read the answer in this edition of "Did you know?".
If you create a DDF for a new device yourself or correct an existing DDF, you might have noticed the XML attribute dmxcversion in the second line, as in the following example from our tutorial for writing a DDF for a moving head (only available in German).
XML: Showtec Indigo 150
<device image="Showtec Indigo 150.png" type="DMXDevice" dmxcversion="3.1.2" ddfversion="1.2">
<information>
    <model>...
In the past years there have not only been many developments that were more or less directly visible on the surface. A lot has also happened "under the hood" - including the DDF syntax. Since version 3.1.1 DMXControl 3 supports different strobe modes, with version 3.1.2 the support handler was introduced as well as additional attributes for easier definition of RGBx matrices. Certainly more functions will follow in the future, which will then have to be mapped in DDF syntax.
To avoid conflicts between DDFs for example for DMXControl 3.2 and the currently installed version 3.1.3, all DDFs with a higher version number are automatically hidden and cannot be added to the project. A corresponding warning can be found in the window of the kernel. This is helpful if you have several versions of DMXControl 3 installed on your PC or if you don't have the latest version yet. The prerequisite is, of course, that the version number is properly maintained.
The XML attribute ddfversion serves - as the name suggests - to distinguish between different versions of a DDF. There are quite legitimate reasons why, for example, the entire internal programs and macros of a device are only rudimentary adopted in the first throw and only fully implemented in the DDF with a second or third revision. The version number is used when comparing DDFs from the DDFLib or another source with your own DDFs. However, this should only be mentioned here for the completeness.
Your :dmxclogo DMXControl-Team :dmxclogo
  • DMXControl Projects e.V.
  • Did you know?
  • DMXControl 3
Comments
Newly created comments need to be manually approved before publication, other users cannot see this comment until it has been approved.
  • Smilies
  • Default Category
  • DMXControl
  • :argh:
  • :shit:
  • :P
  • :D
  • X(
  • 8o
  • =O
  • <X
  • :S
  • X/
  • 8)
  • :huh:
  • :rolleyes:
  • :love:
  • 8|
  • :cursing:
  • :thumbdown:
  • :thumbup:
  • :sleeping:
  • :whistling:
  • :evil:
  • :saint:
  • <3
  • :glaskugel:
  • Smilies
  • Default Category
  • DMXControl
  • :argh:
  • :shit:
  • :P
  • :D
  • X(
  • 8o
  • =O
  • <X
  • :S
  • X/
  • 8)
  • :huh:
  • :rolleyes:
  • :love:
  • 8|
  • :cursing:
  • :thumbdown:
  • :thumbup:
  • :sleeping:
  • :whistling:
  • :evil:
  • :saint:
  • <3
  • :glaskugel:
  • Previous News Did you know? #21 - The Update Button
  • Next News Did you know? #23 - Five ways of starting a cue
Related News
Did you know? Special #5 - DMXControl 3 goes Stream Deck
With DMXControl 3.2 another external control method is introduced: DMXControl can now be controlled with the Elgato Stream Deck.
Logo DMXControl Projects e.V. nutzer99
October 19, 2019 at 10:00 AM
Like 3
0
Did you know? #30 - All effects in focus
As you know, you can store a complete lighting scene with numerous effects in a single scene (cue). But how do you keep track of which fixture functions the effects were applied to? If you have read this Did you know?, you know how and where DMXControl 3 supports you at this point.
February 4, 2021 at 10:00 AM
0
Did you know? #33 - Let's talk about white
When someone tells you that they want to see white on stage or in the show, this statement may seem quite plausible at first glance. But is this really the case? And what has DMXControl 3 to do with it? The answers are given in this Did you know?
December 15, 2021 at 10:00 AM
Thanks 1
0
Categories
  1. Association 359
  2. Association News 214
  3. DMXControl Conventions 120
  4. DMXControl Convention 2026 4
  5. DMXControl 197
  6. Developer News 90
  7. Releases 18
  8. Did you know? 45
  9. Live@Work 40
  10. Current Maintenance Work 5
  11. Forum Guidelines and Informationen 5
  12. Reset Filter
Users Online
  • 4 Members (2 invisible) and 1,099 Guests
  • Record: 34 Users (November 24, 2019 at 7:46 PM)
  • Logo DMXControl Projects e.V. Stefan Krupop
  • Logo DMXControl Projects e.V. Mister X
Legend
  • Logo DMXControl Projects e.V. Administrators
  • Logo DMXControl Projects e.V. DMXControl member
© DMXControl Projects e.V. 2018 - 2026
Gemeinnütziger Verein DMXControl Projects e.V.
Powered by WoltLab Suite™
  1. Terms of use
  2. Legal Notice
  3. Privacy
