1. Forum
    1. Unresolved Threads
  2. Dashboard
  3. News
  4. Members
    1. Recent Activities
    2. Users Online
    3. Team
    4. Search Members
  5. Discord
  6. Society
    1. History
  7. Shop
  8. DMXControl
    1. Übersetzung
    2. Bugtracker
  9. DDF Library
  10. Wiki
  • Login
  • Register
  • Search
Did you know?
  • Everywhere
  • Did you know?
  • News
  • Pages
  • Forum
  • More Options
  1. DMXControl Projects e.V.
  2. News
  3. DMXControl
  4. Did you know?
Did you know? #16 - Freeze on Exit
  • Logo DMXControl Projects e.V. LightningBrothers
  • September 18, 2018 at 10:00 AM
  • 2,402 Views
  • 0 Comments
Did you know, that you are able to keep some DMX controlled lights switched on with DMXControl 3, to have light on stage while the light FOH is already packed in cases? In this "Did you know?" edition, we will show you the needed trick for keep switched on any lights after shutting down DMXControl 3.
Concerts and club parties usually ends in the "deep night" and the disassembling of the complete light and sound equipment starts right after the official end. But what can you do, if only your mounted equipment can keep the stage enlightened for the disassembling, because other external lights are not available? If the light FOH is still online, it is very easy to switch on some LED spots with a special cuelist. The disassembling can start immediately. Unfortunately, the light FOH is in the most cases one of the first area, which is disassembled and packed in its cases. Setting up any DMX controlled light afterwards is then not so easy. In addition, DMXControl 3 stops all cuelists, resets all DMX values to zero and deactivates the connected interfaces in the shutdown process. At least from this point on, all lights are switched off and the stage is dark.
So what can you do, to still have some light on stage, without climbing into the rig for switching on some lights manually? Well, you maybe know the freeze button on the left side of the DMXControl 3 windows. This button helps you not only during the show, where you can freeze effects and movements. This button is also the one to solve our after show lighting problem. Just turn on all lights you need by starting any cuelist or setting up a light scene in the Stage View. Afterwards, you just push the freeze button before shutting down DMXControl 3. With the freeze button enabled, DMXControl 3 does not reset the DMX values and you have the demanded light on stage.
At this point should be noted, that some LED spots will switch off automatically, when they don't receive a DMX signal or they switch over to an internal auto show program. Some device offers you a setting, where you can chose the device's behavior for this case. In addition, some DMX interfaces can start to do unexpected things, when the related DMX software is closed. So just try it, if this solution works for you.
Your :dmxclogo DMXControl-Team :dmxclogo
  • DMXControl Projects e.V.
  • Did you know?
  • DMXControl 3
Comments
Newly created comments need to be manually approved before publication, other users cannot see this comment until it has been approved.
  • Smilies
  • Default Category
  • DMXControl
  • :argh:
  • :shit:
  • :P
  • :D
  • X(
  • 8o
  • =O
  • <X
  • :S
  • X/
  • 8)
  • :huh:
  • :rolleyes:
  • :love:
  • 8|
  • :cursing:
  • :thumbdown:
  • :thumbup:
  • :sleeping:
  • :whistling:
  • :evil:
  • :saint:
  • <3
  • :glaskugel:
  • Smilies
  • Default Category
  • DMXControl
  • :argh:
  • :shit:
  • :P
  • :D
  • X(
  • 8o
  • =O
  • <X
  • :S
  • X/
  • 8)
  • :huh:
  • :rolleyes:
  • :love:
  • 8|
  • :cursing:
  • :thumbdown:
  • :thumbup:
  • :sleeping:
  • :whistling:
  • :evil:
  • :saint:
  • <3
  • :glaskugel:
  • Previous News Did you know? #15 - Direct addressing of fixtures
  • Next News Did you know? #17 - Saving own effects
Related News
Did you know? Special #7 - Input Assignment - Infinite Possibilities
After we have already dealt with the handling of the Input Assignment in our first special, we now present at the end of our Special Week some examples of what can be done with the new Input Assignment.
October 21, 2019 at 10:00 AM
Like 6
0
Did you know? #29 - Skipping the Programmer Filter
Do you want to create new cues especially quickly without checking the selection of device function values to be saved? Read on in this Did you know? how you can do this.
Logo DMXControl Projects e.V. JPK
October 21, 2020 at 10:00 AM
0
Did you know? #30 - All effects in focus
As you know, you can store a complete lighting scene with numerous effects in a single scene (cue). But how do you keep track of which fixture functions the effects were applied to? If you have read this Did you know?, you know how and where DMXControl 3 supports you at this point.
February 4, 2021 at 10:00 AM
0
Categories
  1. Association 359
  2. Association News 214
  3. DMXControl Conventions 120
  4. DMXControl Convention 2026 4
  5. DMXControl 197
  6. Developer News 90
  7. Releases 18
  8. Did you know? 45
  9. Live@Work 40
  10. Current Maintenance Work 5
  11. Forum Guidelines and Informationen 5
  12. Reset Filter
Users Online
  • 2 Members and 1,404 Guests
  • Record: 34 Users (November 24, 2019 at 7:46 PM)
  • Logo DMXControl Projects e.V. JPK
  • Logo DMXControl Projects e.V. Hoc
Legend
  • Logo DMXControl Projects e.V. Administrators
  • Logo DMXControl Projects e.V. DMXControl member
© DMXControl Projects e.V. 2018 - 2026
Gemeinnütziger Verein DMXControl Projects e.V.
Powered by WoltLab Suite™
  1. Terms of use
  2. Legal Notice
  3. Privacy
