Please Help (Problem is fixed Now , Solved it)
I Just installed the newest Dmx2 on a new Dell touch screen laptop & I search the internet for Hours to try to fix it but with no luck
1. The problem is when I use my Keyboard - I hit a bunch of keys (one at a Time) to control My lights & the response time lags way behind the keyboard control & its slow & abot 3-seconds later it finishes , Its not a direct output like my Acer windows 7 laptop I think its a Dell or Windows 8 problem or maybe the touch screen control?
2. I tryied under Keyboard properties the two Properties to the fastest settings (Repeat Delay - Set to short & Repeat Rate to- Fast )
3. I also turned off - Control Panel\All Control Panel Items\Ease of Access Center\Make the keyboard easier
& I turned everything to off
4. Turn Com port setting (bits per second) to the fastest #
5. Hooked up another Usb Keyboar & it also did not help
Also note - Enttec Dmx Open Dmx Usb
Nothing worked Again the Keyboard has some kind of buffer system in Windows 8.1 which is really slow & is not a Direct output & is very slow Keyboard respones time
A. So is it a Windows 8 or 8.1 problem?
B. A Dell or Dell Touch Screen setup problem?
C. Dmx control 2 Software problem?
Can anybody Help?
