Scene Duplication
  • Hello All, I'm having a problem with scene duplication. if I have a scene called say "All On" I highlight it click the add button name it and click OK so far so good it works fine but as soon as I move it to a different position it takes on the characteristics of the previous scene
  • Hello fincaman,
    where did you copy the scene?
    To copy a scene you can go to the Cue Libary in menue Window
    there you can highlight the scene and press the copy button.
    The copied scene will then apear in the list as Copy of Old-Name.
    Now you can rename ist and use it everywere.
    Regards Uwe
