Did you clear the Programmer after saving a cue? With default settings the Programmer content has higher priority then cuelists, which results in a cue actually not playing.
I can't find a way of saving a cue how do you do that ?
Thanks Tried that no difference
Hello Sorry but the programmer is completely blank but I have discovered that if I exit DMXC then open it again my cues are correct
Hello again, I have had a little progress in that I can now delete a cue I didn't realize and it didn't say anywhere that the method of selecting a cue is by clicking the square box to the left but after many hours of trying I can't create cues they seem to take on the values of the last cue I have created. There seems to be no method of saving a cue.
Could anyone take the time to tell me the correct method of creating cues please
regards
Kevin
Hello and thanks for the help just one thing are there any keyboard shortcuts in DMX 3 ?
Hello again, I've been trying to do this myself I have added my fixtures 5 generic dimmers MRGBW I have created a cue list but have problems. All the cues take on the values of the last cue programmed Also I can't delete a cue any help would be appreciated
Hello all, I've been using DMC 2 for some years but think it's time to move to DMC 3 are there any instructions or tutorials in English ?
I have used a vellaman for years the fades were a bit steppy at the bottom so I bought an Enntec USB Pro no difference at all
Hello I've had the same problem, the Enttec was working fine with DMXC2 so I thought I would try Freestyler, when I went back to DMXC I got the same message as you. I uninstalled Freestyler uninstalled DMXC then reinstalled DMXC it was fine after that, hope this helps
Hello again, sometimes it starts as picture attached and sometimes it starts normally
Hello, sorry but I cant find the English forum, I'M using DMXC2 and am finding that all the vertical blue value bars are full on at startup. Can anyone help
Regards
Kevin Mooney
Thanks all found it
Hello All and a happy new year, I have been using DMXC 2 for some years with a Vellaman interface and have been very happy. As is the way of things I thought I would move on to DMX 3 and buy an Enntec Open DMX interface. I have installed DMXC 3 but I can't find the startup icon where is it please ?
Thanks worked fine
Hello, I can't find uDMX in the list of output plugins but it is listed in the list of supported plugins how do I Install it
Hello all, I have just added a Lazer to my led lights, the LEDS start at address 1 and the lazer at address 21. I have created a list of scenes for everyday use and a separate scene sheet for the lazer. I would like them to work independently so that if I have the lazer on or off I can still use the other led scenes without it affecting the lazer is that possible ?
I copied by just clicking the green + sign but I'll try what you say
Hello All, I'm having a problem with scene duplication. if I have a scene called say "All On" I highlight it click the add button name it and click OK so far so good it works fine but as soon as I move it to a different position it takes on the characteristics of the previous scene
Hello Again, I'm sorry but I have failed to transfer my project. I have copied the files to a stick with Pack and Go, I have extracted them on the target computer, I have three folders DDFs, Project and Settings. Where do I put these ? I have found where DMXC programme files are stored on the target computer
Thanks I'll try that when the time comes
Regards
Kevin
