Hello,
I have several cues in a cuelist and I want that when I click on "Go". All cues start simultaneously.
Is it possible and How because I do not find the solution ?
Thanks
Hello,
Thanks
Hello,
you just have to set the time to 0 0 0 then it should work ![]()
Regards McMaxxter
Set Trigger to follow or wait and Trigger Value to 0 for all cues except for the first.
Dennis
Hello,
Thanks
Sorry, but :
for the timecode trigger, it doen't work
for the follow trigger, it doesn't work because of the fade time
for the wait, It seems that DMX Control has a bug because after several test, I didn't deal with this solution
Il found a solution with the "GoTo" command. If you launch Goto on the last cue, every cues starts at the same time (every cue have a manual trigger).
Regards
Jeff
If you think that you've found a bug (i've not yet looked into it) please file a bug report
thanks,
Dennis
