Lights flicker using ENTTEC open DMX USB
  • I am using DMXControl to run a generic dimmer pack through the ENTTEC open USB interface. The program works fine except the lights flicker continuously at any level. The ENTTEC support center states this could happen because "some parameters (Break length, MaB length, inter-byte time) of the DMX signal can vary from frame to frame". They suggest adjusting the frame rate in the software, but I don't see how to do this. Has anyone else experienced this problem? I am not very technical and would appreciate any help or advice.
    Thank you!
